Hi everyone!
I recently started experimenting with relays. I would like to give my relay a separate power supply so as to isolate Arduino from the relay.
I noticed though that my relay doesn't have a 3-pin jumper but only 2 pins (JD-VCC and VCC).
Can you tell me if it is possible to supply this type of relay with an external power supply? If yes, then on which pins should I put external power?
I'd suggest you attach the external vcc to the vcc pin (the pin at the top where there is a cable attached already).
Just make sure you have the grounds connecting.
In other words:
external vcc goes to relay-board
external gnd goes to relay-board and Arduino power supply (both gnd are connected)
Arduino powered as before
If you want to power the relay board from a seperate supply, and also have opto isolation.
Remove jumper.
Connect relay supply to JD-VCC (not VCC) and relay ground.
Connect Arduino 5volt to VCC (on the row of pins).
Connect Arduino outputs to relay inputs.
DO_NOT_CONNECT Arduino ground to relay ground (doing so would defeat opto isolation).
Leo..
Thanks everyone!
I solved by removing the jumper and connecting the VCC of the external power supply on the JDVcc (relay) and the GND (of the power supply) on the GND pin (removing first the GND from Arduino).
Something like that:
