Relay won't do anything when its told so
Hi! I'm trying to power a 24v DC ventilator with a relay (RELA-1CH)
My code is working, the led on the relay is turning on, but the fan won't move at all.
I'm currently using this wiring: 5dbaefbef8a3a32f7309e2b89fc8a1be.png (1998×1272) (pinimg.com)
I tried the output on the other side as well, but the fan was running continuously.
Any help is appreciated!
If you are sure the relay is operating then I guess the wiring isn't as you think. Have you checked with a multimeter that the contacts are as you believe them to be?
Please can you post your image here, not a link to somewhere else.
Thanks
Show us a good image of your ‘actual’ wiring.
Give links to components.
Posting images:
Thanks for the help! I checked my code, and the pin (that the relay was on) was not set to output!
Thanks!
My code is working,
Do you remember the bit in the how to get the best out of this forum tutorial where it says we need to see your code...?
Glad you got it working. Please and you edit the title to include the word Solved.
