I have written a script that looks at 3 inputs and if they are all high then it should turn on a relay and then turn it off after 1 second. It then starts a timer to create a delay before turning a second relay on and then off after 1 second. It then repeats the loop. It is turning on the relay but then just leaves it on and then nothing else occurs. The code appears to be looping because if I trigger one of the 3 inputs, it responds as expected. I can't for the life of me figure out why it is hanging up. Please help.
Here is my code:
int relay3=5;
int relay4=4;
int faultLED=7; //this is relay1 on the relay shield
int scaleFactor=1000; // this converts seconds to miliseconds
int switchDelay=1000; //length of button press in miliseconds
unsigned long altDelay=90; //interval between button presses in seconds
int sovr1=1;
int sovr2=2;
int sovr3=3;
int toggleState=0;
unsigned long startDelay;
pinMode(relay3,OUTPUT);
pinMode(relay4,OUTPUT);
pinMode(faultLED,OUTPUT);
pinMode(sovr1,INPUT_PULLUP);
pinMode(sovr2,INPUT_PULLUP);
pinMode(sovr3,INPUT_PULLUP);
if (digitalRead(sovr1)==LOW || digitalRead(sovr2)==LOW || digitalRead(sovr3)==LOW){
digitalWrite (faultLED,HIGH);
exit(0); //this makes the fault permanent till a reset occurs
else if (toggleState==0){
digitalWrite (relay3,HIGH); //pressing selection 1 on first machine
delay(switchDelay);
digitalWrite(relay3,LOW); //releasing selection 1 on first machine
toggleState == 1;
startDelay == millis();
else if(toggleState == 1 && (millis()-startDelay) >= (altDelay * scaleFactor)){
toggleState == 2;
else if(toggleState == 2){
digitalWrite (relay4,HIGH); //pressing selection 2 on first machine
delay (switchDelay);
digitalWrite (relay4,LOW); //releasing selection 2 on first machine
toggleState == 3;
else if (toggleState == 3 && (millis()- startDelay) >= (altDelay * scaleFactor)){
toggleState == 0;
Hello justinpigott
It seem to be a school asignment, isn´t it?
I have seen a lot of these school asignments here. Take some time and use the Serach Forum function to get some ideas for a proper solution.
No. Not a school project. I have been out of school for 20 years. This is a work project. I don't usually need to write code but needed to in this instance. I don't see anything wrong with the code and the place it is hanging up seem the most unlikely spot to hang up on. I have spent the last few hours trying to figure out what is going wrong. If you see my error please help a brother out.
Hello justinpigott
Replace all delay()´s by a timer function.
Design a FSM to simplify the sketch, using the switch case statement, to handle the "toggle states".
startDelay == millis(); Checks if startDelay is equal to millis();
startDelay = millis(); startDelay takes the value of millis();
toggleState == 0;
toggleState == 1;
toggleState == 2;
toggleState == 32;
toggleState == ?; Checks if toggleState is equal to ?;
toggleState = ?; toggleState receives the value of ?;
One of the most common mistakes that new programmers make is to confuse the assignment operator (= ) with the equality operator (== ). Assignment (= ) is used to assign a value to a variable. Equality (== ) is used to test whether two operands are equal in value.
