I thought that I can control it.
The led on the relay board turn on and off well, but I can't hear the sound of the coil, and when I've tried to connect a supply to the COM and NC connection, nothing happenend.
Is the relay broken or I'm missing something?
Thanks for the answer, I'll try to explain the connections.
The relay board require 5V so I supply that with my arduino board, connecting 5V pin to vcc, and arduino Gnd to relay Gnd. The relay have the jd-vcc short with the vcc.
I tried connecting a 12V 1A transformer to the Com for use a led (just for try). The hot line, the + wire, is connected to com, the Normally closed is connected to the led.
Narsil22:
The relay board require 5V so I supply that with my Arduino board, connecting 5V pin to vcc, and Arduino Gnd to relay Gnd. The relay have the jd-vcc short with the vcc.
You can only supply the (5 V) relay board from the Arduino Vcc if you provide a 5 V power supply to the Arduino board. USB power may work but attempting to power it through the on-board regulator is asking for heartache.
Paul__B:
I have a similar relay Paul, and the singals are fed directly from the digital pins on my UNO. Should I not do this? (sorry to hijack your thread Narsil22!)
