relay
hello every one
i m using a relay to controll 12v dc water pump.
the relay works well but when i use if or while statements the relay always remain on. kindly guide me about this
code:
int xAxis, yAxis;
int x = 0;
int y = 0;
const int control = 9 ;
Serial.begin(9600); // Default communication rate of the Bluetooth module
pinMode(control, OUTPUT) ;
// Default value - no movement when the Joystick stays in the center
xAxis = 510;
yAxis = 510;
while (Serial.available() == 0) {}
x = Serial.read();
delay(10);
y = Serial.read();
delay(10);
xAxis = x * 4;
yAxis = y * 4;
// Y-axis used for forward and backward control
if (yAxis < 470) {
digitalWrite(control, HIGH);
digitalWrite(control, LOW);
else if (yAxis = 510){
delay(25000);
else if (xAxis = 510){
delay(25000);
if (yAxis = 510){Oops
Common beginner mistake: '=' is the assignment operator for setting the variable on the left to the value on the right.
You want '==', the equality operator. It compares the value on the left with the value on the right and return 1 (true) if they are equal or 0 (false) if they are not equal.
