i trie to make a circuit that can switch automaticly between battery and the wall outlet but if i let switch my relay and couses a voltage drop and then resseting the arduino due to power disconecection how can i fix the voltage drop
Don't power the relay from the Due.
that was not wat i ment
i am giving you a circuit
Post a schematic.
You may be able to get away with using super caps to supply power during the switching power time.
As you might see the cap is rated for 2.7V. If 2 are wired in series, so it can handle 5V and place between the output of the relay and ground.
I use a similar power switching thingy but with 4 caps. Works well.
Yuppers, put the super caps on the relay module output. You may need to build a bank of caps, depending on current draw.
Have you considered using Schottky steering diodes instead of a relay?
