Relay_Output
Hi guys, please i need help.
I need to implementate PID regulator on arduino that can generate a PWM signal to control a relay output. I use the library example (title Relay_Output) but I don’t understand the code:
#include <PID_v1.h>
#define PIN_INPUT A0
#define RELAY_PIN 6
double Setpoint, Input, Output;
double Kp=2, Ki=5, Kd=1;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
int WindowSize = 5000;
unsigned long windowStartTime;
windowStartTime = millis();
Setpoint = 100;
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, WindowSize);
myPID.SetMode(AUTOMATIC);
Input = analogRead(PIN_INPUT);
myPID.Compute();
if (millis() - windowStartTime > WindowSize)
{ //time to shift the Relay Window
windowStartTime += WindowSize;
if (Output < millis() - windowStartTime)
digitalWrite(R
else digitalWrite(RELAY_PIN, LOW);
Question 0) This is a PID controller?
Question 1) Why in function SetOutputLimits the second variable is WindowSize = 5000? The max limit is 255 or not?
Question 2) What is the Output? Output is calculate by compute() but i don’t understand this function
Question 3) What is the frequency of PWM output signal?
Question 4) In which way the dutycycle of signal is calculated in every loop?
I receive the input signal by temperature sensor and my target is keep the temperature costant, is enaugh this code? Thank you very much guys.
Your code is clearly incomplete.
Here’s a pretty good write up by the PID Library’s author: Improving the Beginner’s PID – Introduction « Project Blog
It’s multi-part, so keep clicking on the “NEXT >>” link to read more.
