thanks for replying…
here is the code:
// Basic 4 Realy board connection
// Each relay is turned on for 2 seconds and then off.
// You can here them click as there state changes from off to on and on to
// off.
// You will also see the corresponding Red LED on the 4 Relay board
// light up when the relay is on.
// define names for the 4 Digital pins On the Arduino 7,8,9,10
// These data pins link to 4 Relay board pins IN1, IN2, IN3, IN4
#define RELAY1 6
#define RELAY2 7
#define RELAY3 8
#define RELAY4 9
// Initialise the Arduino data pins for OUTPUT
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
digitalWrite(RELAY1,LOW); // Turns ON Relays 1
delay(2000); // Wait 2 seconds
digitalWrite(RELAY1,HIGH); // Turns Relay Off
digitalWrite(RELAY2,LOW); // Turns ON Relays 2
digitalWrite(RELAY2,HIGH); // Turns Relay Off
digitalWrite(RELAY3,LOW); // Turns ON Relays 3
digitalWrite(RELAY3,HIGH); // Turns Relay Off
digitalWrite(RELAY4,LOW); // Turns ON Relays 4
digitalWrite(RELAY4,HIGH); // Turns Relay Off
so there is 4 relays and i want 8 with no delay.
also i prefer to monitor the situation of the relay over my android phone whether it’s off or on
thanks again
