Relays will remain on when code is uploaded,
Hello readers
Hope you all are fine, I have query when I uploading relay code in serial communication, at the upload time all relays are will remain ON, However I want to control my own self through mobile phone via bluetooth code is following as:
#include <SD.h>
char val; // variable to receive data from the serial port
int ledpin; // LED connected to pin 2 (on-board LED)
pinMode(ledpin = 12, OUTPUT); // Engine Ignition Relay.
pinMode(ledpin = 11, OUTPUT); // Engine OFF Relay.
pinMode(ledpin = 10, OUTPUT); // Generator Load Relay.
pinMode(ledpin = 9, OUTPUT);// K-Electric Load Relay.
pinMode(ledpin = 8, OUTPUT);// Solonoid Volve Relay.
pinMode(ledpin = 7, OUTPUT);// Reset Relay.
pinMode(ledpin = 6, OUTPUT);
pinMode(ledpin = 5, OUTPUT);
Serial.begin(115200); // start serial communication at 115200bps
if( Serial.available() ) // if data is available to read
val = Serial.read(); // read it and store it in 'val'
if( val == 'A' ) //
digitalWrite(ledpin = 12, HIGH); // Engine Ignition Start Engine UP
if( val == 'a' ) //
digitalWrite(ledpin = 12, LOW); // Engine Ignition Start Engine Down
if( val == 'B' ) //
digitalWrite(ledpin = 11, HIGH); // Engine OFF
if( val == 'b' ) //
digitalWrite(ledpin = 11, LOW); // This is for spare
if( val == 'C' ) //
digitalWrite(ledpin = 10, HIGH); // Generator load will ON
if( val == 'c' ) //
digitalWrite(ledpin = 10, LOW); // Generator load will OFF
if( val == 'D' ) //
digitalWrite(ledpin =9 , HIGH); // K-Electric load will ON
if( val == 'd' ) //
digitalWrite(ledpin =9 , LOW); // K-Electric load will OFF
if (val == 'E')
digitalWrite(ledpin = 7, HIGH); // CNG
digitalWrite(ledpin = 7, LOW);
if (val == 'e')
digitalWrite (ledpin= 7, HIGH); // CNG
digitalWrite (ledpin= 8, HIGH); //Petrol
if (val == 'F')
digitalWrite (ledpin = 8, LOW); // Petrol
if (val == 'f')
digitalWrite (ledpin = 8, LOW); //System off
digitalWrite (ledpin = 7, LOW); //System off
// Reset all Relay function.
if (val == 'R')
digitalWrite(ledpin= 12, HIGH);
digitalWrite(ledpin= 11, HIGH);
digitalWrite(ledpin= 10, HIGH);
digitalWrite(ledpin= 9, HIGH);
digitalWrite(ledpin= 8, HIGH);
digitalWrite(ledpin= 7, HIGH);
digitalWrite(ledpin= 6, HIGH);
digitalWrite(ledpin= 5, HIGH);
digitalWrite(ledpin= 12, LOW);
digitalWrite(ledpin= 11, LOW);
digitalWrite(ledpin= 10, LOW);
digitalWrite(ledpin= 9, LOW);
digitalWrite(ledpin= 8, LOW);
digitalWrite(ledpin= 7, LOW);
digitalWrite(ledpin= 6, LOW);
digitalWrite(ledpin= 5, LOW);
if (val == 'r')
delay(100000);
What is the question?
once relay code uploaded in arduino , relay will remain on, however I want to control my self
This kind of code
is very unusual and may or may not be doing what you think it should do. The more usual syntax is
pinMode(12, OUTPUT);
That is, remove the ledpin= and just use the pin number
There is also
 delay(100000);
Not sure if you intend to wait 100 seconds there instead of the 1 second you used everywhere else.
Usual reminder to use the code tags...
