Relays
Hello!
I've set out to make a thermostat with a simple threebutton user interface and two LEDs and a 2*16 LCD display for information / response.
I've got it all toghether in a way, but one thing I've compleatly forgot about:
-How do I complete or short- a 230 volt circuit, using a 0-5 volts control signal?
And what if i need to control only 12 volts, using a 0-12 volt control signal?
I have peeked around, but I've not yet had any succsess finding something that explains this in a way that I can relate to / understand.
-Alexander
take a look of this:
I've seen that diagram, and it's for DC, I'm going to use AC.
I'm guessing it's a difference?
Greetings,
There's a difference between the relay coil and the relay contacts — which is the whole point.
You can buy relays with almost any coil voltage between 5V and 240V (or more) either AC or DC. These relays are available with gold-plated contacts rated for a few milliamps to huge copper buttons rated for hundreds of amps.
Good luck!
There is a structural difference between AC and DC relays, but I don't think there's a difference in how you use them. Just buy the correct relay for your task and the tutorial should apply.
