Relays
So I'm looking at buying this relay module for a project. 6 of the 8 relays at most will be used at the same time. My question is will I have to use some external power source in order to activate the relays? Or will the arduino's 5 volts be enough? If I need an external power source how would I go about it? Thanks!
Those relays (coils) draw 75-80mA each when active.
An Uno draws about 50mA.
USB power is 500mA max (an Uno has a 500mA polyfuse).
External power for the relay board might be wise (old 5volt cellphone charger).
Leo..
Edit:
Is this for your car tail light project?
Then you also need a suitable buck converter.
The 5volt regulator of an Uno can only power one relay when powered by 12volt.
Wawa:
Yeah it is, is a buck converter just like a 12v to 5v step down? So a car charger usb adapter?
Most car buck converters (cigarette lighter types) can deliver more than 500mA.
I see no problem powering that 8-relay module and the Uno from it.
Leo..
Ok thanks a lot friend!
Why not get a relay module with 12V relays that control the relays with 5V logic? Then you have the relay coil power from the car's 12V system.
https://www.amazon.com/8-Channel-Module-Optocoupler-Trigger-Arduino/dp/B00PU3JYZO/ref=sr_1_7?ie=UTF8&qid=1527086988&sr=8-7&keywords=12V+relay+module
