For instance do I have the transmitting arduino reading the photo transistor on the analog pin converting the voltage to a integer (0-1024) then that integer is sent as binary to the receiver with the bit rate that is given by the wireless connection?
Your current Arduino keeps on doing what it is doing. It's currently measuring time; it's not relevant how. As I visualize it, it's something like
a button is pushed to turn on the start light; this will also start a timing
2)
when the beam is interrupted, the difference between the start time and the end time is measured
The added step would be to send the measured time (and not the voltage) to the other Arduino at the moment that the beam is interrupted.
If a lap time is significantly greater than the required transmission time, you should be OK from a timing perspective to continuously send data when the beam is interrupted; e.g. your transmission time is 200ms and your lap time is 2 seconds (no idea)
If you only want to measure one lap and stop, the transmission time is irrelevant as long as the next start is after the transmission has finished (you mention minutes in between).
they would communicate on the TX,RX pins.
You should not use the serial port for simple transmitters (like the ones I linked); the transmission basically relies on a balance between ones and zeroes. Sending a bit pattern 0000001 via the serial port will more than likely not work. That is why the RadioHead library does some tricks to achieve this; I have not completely analysed it. This is the reason why the transmission with RadioHead is relatively slow relatively slow.
If you have intelligent transmitters (no idea what exists), they will handle this for you and you don't need the RadioHead library and probably you can use the serial port with them.
how much faster can you go than the default 2 kbit/s
I don't know how much faster you can go. Might very well depend on the environment (how many other 433 transmitters are there that can interfere with your one) and the distance that you want to cover. RF has never been my strong point (still getting my feet wet on this).
The below code can act as a guide if you go with the cheap transmitter / receiver and the RadioHead library.
// number of transmit repeats for one packet
// note: you need to find a balance between transmit time and lap time
#define NUMTXREPEATS 5
// number of laps to measure
#define NUMLAPS 5
// pin for start button
const byte startButton = 4;
// pin for beam; this uses a digital pin for this demo
const byte beamPin = 5;
// pin for transmit in progress LED
const byte TXinProgressLed = 13;
// button connencted between pin and ground; active LOW
pinMode(startButton, INPUT_PULLUP);
// sensor connencted between pin and ground; active LOW
pinMode(beamPin, INPUT_PULLUP);
// transmit in progress LED
digitalWrite(TXinProgressLed, LOW);
pinMode(TXinProgressLed, OUTPUT);
// flag to indicate if measuring has started
static bool fStarted = false;
// timing start time
static unsigned long startTime = 0;
// lap timing start time
static unsigned long lapStarttime = 0;
// current 'time'
unsigned long currentTime = millis();
// lap counter
static byte lapCounter = 0;
// if start button was not pressed yet
if (!fStarted)
// if start button pressed
if (digitalRead(startButton) == LOW)
// indicate 'started'
fStarted = true;
// set start time
startTime = currentTime;
// set lap start time
lapStarttime = startTime;
// if not started yet
if (!fStarted)
// nothing to do
return;
// if beam not interrupted
if (digitalRead(beamPin == HIGH))
// nothing to do
return;
// increment lap counter
lapCounter++;
// calculate lap time
unsigned long lapTime = currentTime - startTime;
// reset lap start time time for next lap
lapStarttime = currentTime;
// transmit N times to improve chances of reception at the other side
// note that this transmit (with RadioHead) is blocking (as far as I know)
for (int cnt = 0; cnt < NUMTXREPEATS; cnt++)
transmit(lapCounter, lapTime);
// if all laps completed
if (lapCounter == NUMLAPS)
// total time
unsigned long totalTime = currentTime - startTime;
// transmit total time; you can repeat this
transmit(0, totalTime);
// reset
fStarted = false;
lapCounter = 0;
void transmit(byte counter, unsigned long duration)
// combine data into one packet
// indicate transmit in progress
digitalWrite(TXinProgressLed, HIGH);
// transmit packet
// indicate transmit in progress finished
Note
To improve reliability, it sends data a number of times; you need to find a balance between lap time and and transmit time. The receiver only has to receive one packet correctly; if it receives more, it can compare and ignore if they are the same. You can also add a sequence number to a packet so you can detect dropped packets. As noted in the code, the RadioHead.transmission is blocking as far as I know.
As I said, if your lap times are much larger than the transmit time, you should not have an issue because the timing for a lap is restarted before the data is transmitted.
You can change the approach and not use a for loop; the effect of the blocking will be less noticeable; but it will depend on your needs if that is required.
The remainder of the code is non-blocking. If there is nothing to do, leave loop(); it's basically a very basic state machine. The code measures lap times and total time.
From my short experience with the cheap 433MHz transmitter/receiver, it's not the most reliable communication. The one moment one in three packets can be dropped (hence the NUMREPATS of 5), the next moment one in hundred or thousand.
