Reliablity issues in PWM reading with ISR in class definition
Hello everyone.
I'm trying to read the duty cycle of a PWM signal using an Arduino MEGA 2560 and hardware interrupts. I'm well aware of the issues that arise from using the attachInterrupt function with an ISR defined as a class member function, but reading this topic I found the way to get around it. I got my code partially working, but I have two problems:
1. The interrupts work unreliably. After flashing the Arduino with the firmware sometimes the ISR behaves as it wasn't triggered at all, keeping the duty cyle at 0 (as it is initialized).
2. When it is measured, a duty cycle (that is known a priori to be constant) keeps changing randomly and rapidly, even though the same ISR used as a regular function outside the class definition works correctly and reliably.
My question is the following: what is hidden difference that I can't see between my "object-oriented" implementation and the regular "functional" one?
I post below the codes for both implementations.
#define PWM_CHANNEL 2
int pwmDutyCycle_throttle = 0;
  Serial.begin(115200); // Serial to PC
  attachInterrupt(digitalPinToInterrupt(PWM_CHANNEL), decodePwm_1, CHANGE);
void loop(){
Serial.println(pwmDutyCycle_throttle);
void decodePwm_1() {
  static unsigned long riseTime = micros(); // initialize riseTime
  if (digitalRead(PWM_CHANNEL_1) == 1) { // the signal has risen
    riseTime = micros(); // save the rise time
  else { // the signal has fallen
    pwmDutyCycle_throttle = micros() - riseTime; // compute the duration of the high pulse
And the code with the ISR defined within the class definition:
class pwm_reader_attachable_t {
  uint8_t pin;          /**< physical pin on the board */
  uint16_t pulse;      /**< duration of the high edge (the pwm reading) */
  uint16_t pulse_real; /**< a stabilized version of the reading (for fast varying signals) */
  uint16_t edge_time;  /**< timing of the last high edge */
  uint8_t counter;  /**< counter (actually used for the encoder) */
  uint8_t read;         /**< Last reading of the pin, for triggering pulse width evaluation */
  public:
    void
      setup(pin_t pin, void (*ISR_callback)(void), int value),
      handleInterrupt(void);
      inline pulse_t get_pulse() { return pulse; }
    pwm_reader_attachable_t() {
    counter = 0;
    pulse = 0;
    pulse_real = 0;
    edge_time = 0;
    read = 0;
  private:
    void(*ISR_callback)();
void pwm_reader_attachable_t::setup(pin_t pin, void (*ISR_callback)(void), int value)
  //pinMode(pin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(pin), ISR_callback, value);
  interrupts();
inline void pwm_reader_attachable_t::handleInterrupt(void)
    if (digitalRead(pin) == 1) { // the signal has risen
    pulse = micros() - riseTime; // compute the duration of the high pulse
pwm_reader_attachable_t* motor;
pulse_t DC=0;
  motor = new pwm_reader_attachable_t();
  motor->setup(PWM_CHANNEL, []{motor->handleInterrupt();}, CHANGE);
    DC = motor->get_pulse_real();
    Serial.println(DC);
Thank you all in advance!
I can't get #2 to compile:
sketch_mar28c:11:13: error: 'pin_t' has not been declared
sketch_mar28c:13:14: error: 'pulse_t' does not name a type;
and stacks more . . .
You need do declare your variables used inside the ISR as volatile
Code 1
volatile int pwmDutyCycle_throttle = 0;
  int localValue;
  noInterrupts();
  localValue = pwmDutyCycle_throttle;
  interrupts();
Code 2 (with some fixes)
typedef  byte pin_t;
typedef uint16_t pulse_t;
    volatile uint16_t pulse;      /**< duration of the high edge (the pwm reading) */
  public:
    void setup(pin_t pin, void (*ISR_callback)(void), int value);
    void  handleInterrupt(void);
      pulse_t x;
      noInterrupts();
      x = pulse;
      interrupts();
      return x;
    pwm_reader_attachable_t(void) {
      counter = 0;
      pulse = 0;
      pulse_real = 0;
      edge_time = 0;
      read = 0;
  private:
  interrupts();
pulse_t DC = 0;
  motor->setup(PWM_CHANNEL, [] {motor->handleInterrupt();}, CHANGE);
  //motor->setup(PWM_CHANNEL, motor->handleInterrupt, CHANGE);
  DC = motor->get_pulse();
  Serial.println(DC);
6v6gt:
Oops, I'm sorry. In coping and pasting the code I forgot to change the pin_t definition to uint_8.
blh64:
Thanks for the tip about volatile variables (arrrgh I should read the documentation of the functions I use) !
Still, I get inconsistent values between Code 1 and Code 2: Code 1 works fine, as expected. Code 2 returns random duty cycle values, far from the expected one and rapidly changing over time.
Any other ideas ?
Thanks for your answers so far
