Reloading-Powder-Hopper-Level-Gauge-and-Alarm
Good morning
I have a project that I copied but I'm stuck.
Equipment
AZDelivery 3 x NodeMCU Amica Module V2 ESP8266 ESP-12F Carte de Développement WiFi WiFi avec CP2102 Compatible avec Arduino incluant Un E-Book!
-Amazon.fr
GIAK KY-040 Rotary Encoder 360 Degrés Codeur Rotatif 5 Pcs De Codeur avec Capuchon de Bouton pour Arduino
-Amazon.fr
DollaTek VL6180X Capteur de distance de vol
-Amazon.fr
AZDelivery Écran ST7735 TFT 1,77 Pouces 128x160 Pixels Compatible avec Arduino et Raspberry Pi incluant Un Ebook!
-Amazon.fr
here is the site where I copied everything
and my problem is that when I compile this is what happens
C:\Users\lcper\Downloads\Reloading-Powder-Hopper-Level-Gauge-and-Alarm-master\Reloading-Powder-Hopper-Level-Gauge-and-Alarm-master\PowderHopperGauge\PowderHopperGauge.ino:3:10: fatal error: user_interface.h: No such file or directory
 #include "user_interface.h"
compilation terminated.
exit status 1
Compilation error: user_interface.h: No such file or directory
I installed all the libraries and installed the drivers for the CP2102 card.
Thank you for your help
TBC, you installed the user_interface library?
I can't check to se if the IDE library manager has it in its view. If not, the library is very probably
a7
So I have to modify the library? yes, how to do it? I'm really a beginner Thank you
No. You do have to install it, however. if you think you have, the error muessafe indicates that you failed.
I can't google enough through the tiny window, but:
Either the library can be found using the tools to directly install libraries that are in the IDE, or you will have to download the zip file from the repository I linked above and install it.
TBH how that all goes is knowledge that lives somewhere between my elbows and fingers - I can't recall and am incompetent to outline the exact steps.
So with any luck I'm not the only one reading, and someone can help before I look again when I am next in the lab. :expressionless:
a7
