Remainder operator (%) is unable to use doubles and int as operands even though documentation says it can
This is the code I've written.
const int ledPin[] = {4,5,6,7};
long int numAleat; // Escolhe um número de 32 bits aleatório
int comprimento;
int i;
  for (int i=0;i<4;i++){
  pinMode(ledPin[i], OUTPUT);
  numAleat=48367;
  String stg_numAleat;
  stg_numAleat = String(numAleat);
  int comprimento = stg_numAleat.length();
  unsigned primeiro = (numAleat%10);
  unsigned segundo = (numAleat /10U) %10;
  unsigned terceiro = (numAleat /100U) %10;
  unsigned quarto = (numAleat /1000U) %10;
  for(i=0;i< 10*comprimento +1;i= i +10){
    if (i==0){
      Serial.println(numAleat%10);
   else{
     for(int a=0; a=comprimento;a++){
    Serial.println((numAleat/ pow(10,a) ) %10);
    delay(1000);  }
delay(9999);
Serial.println(quarto);
  delay(99999);
The specific error is in this line
It spews this error
Compilation error: invalid operands of types 'double' and 'int' to binary 'operator%'
I've tried converting it to int
    Serial.println(int(numAleat/ pow(10,a) ) %10);
But then it just spams the Serial Monitor with a bunch of 0s.
How to fix this?
Maybe a<=comprimento ?
Do you want an integer or a float? The modulo operator ( % ) does not work with floats, you will need to cast the result of the division to an integer type before using modulo, or you can use fmod() for a floating point answer.
Lol, thanks. I've missed that completely
why not
   long pwr = 1;
   for(int a=0; a=comprimento; a++) {
    Serial.println( (numAleat/pwr) %10);
    pwr *= 10;
and abandon floating point use entirely.
