I'm having problems using a remainder to keep a value within a specified range. I'm using a rotary encoder to increment up and down, and this bit of code sets the offset to a clock value that comes into my code in GMT only. So I want to be able to offset that GMT time to get local time.
It works well when I increment up, but when clockOffset is an unsigned int and I increment down, i'll get to zero, and then it goes to 15, instead of 23 like I would expect. What am I missing here?
void incrementOffset() {
unsigned char result = rotary.process();
if (result == DIR_CW) {
clockOffset = (clockOffset + 1) % 24; // increment up one within range of 0-23
else if (result == DIR_CCW) {
clockOffset = (clockOffset - 1) % 24; // increment down one within range of 0-23
if (clockOffset == 23) clockOffset = 0; else clockOffset++; // increment up one within range of 0-23
if (clockOffset == 0) clockOffset = 23; else clockOffset--; // decrement one within range of 0-23
Interesting, makes perfect sense, thank you. I suppose this is probably the best solution since this function is an ISR, so I should keep it as light as possible.
for readability and let the compiler optimize the switch.
Or using a if and testing first with DIR_NONE which is possibly going to be >99% of the time and returning will save time as you won't be doing the two other tests.
EDIT: if it's an ISR, is it called only when you move the rotary encoder or on a time base?
if it's the former you know DIR_NONE is not possible so you could write
When I said relatively expensive, I meant compared to the code I suggested which is only a comparison and an increment/decrement. Modulo is probably not not so slow that it would cause problems with rotary encoders at normal human speeds, but for an encoder attached to some high speed mechanism it might cause missed signals.
Just out of interest I made some measurements and did a quick back of the envelope calculation.
On a Pro mini, this operation seems to take somewhere between 4µs (single measurement) and 6µs (1,000,000 measurements including loop overhead and an addition to avoid the compiler optimising everything away) so maybe 5µs would be a safe bet.
If the interrupt is triggered on every change (48 times per rotation) and we assume there is no other overhead, then we could reach 250,000rpm, enough to keep up with a dental drill.
It would be fun to see that in action. I do not think the rotary encoder would survive.
