Remember you're a button
Just having some small confusion, about how to turn an LED on with one button press and when you press the button again; turns the led off.
Instead of lighting up when held down. Surely it's something very simple!
Sorry for the extremely basic question!
Do a search for "debouncing button" to get on your way.
Thank you very very much!! :slight_smile:
This sketch is maybe want you want, every time you push a button a LED wil turn on, and next time you push itthe LED will turn off.
There is no debouncing , and there should be
int vent=100;
const int buttonPin = 7;
int flag=0;
int buttonState = 0;
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(buttonPin, INPUT);
// digitalWrite(4, HIGH);
buttonState = digitalRead(buttonPin);
delay(vent);
Serial.print(buttonState);
if (buttonState==HIGH){
if (flag==1) {
flag=0;
flag=1;
if (flag==1){
Serial.print("HIGH\n");
if (flag==0){
digitalWrite(4, LOW);
Serial.print("LOW\n");
I wrote it in an easy way..
Hope this helps you.. :slight_smile:
int button_pin = 11;
int led_pin = 13;
int button_state = 0;
int led_state = LOW;
void setup(){
  pinMode(button_pin, INPUT);
  pinMode(led_pin, OUTPUT);
void loop(){
  if(button_state == HIGH){
    led_state = !led_state;
    digitalWrite(13, led_state);
    delay(100);
Cheers for the response, really good looking code, but couldn't get the LED to come on!
Joy:
Enjoy your rapidly blinking LED. That will, as long as the button is pressed, toggle the LED every 100ms.
