Remote button is too sensitive
Hello I'm trying to use my 4channel wireless module with remote. Everything is working but my remote button is to sensitive. Im using buttonState = digitalRead(buttonPin); to get signal from remote. When I push button light should turn on and when I push it again it should turn off. The problem is that sometimes when I push button light turn on and off. It's very annoying. Is there any code trick which I could use in my sketch to make my button less sensitive? Of course I can use two buttons for one light. One for turn on and another for turn off but I prefer first option :)
const int buttonPin = 12;
const int ledPin =  13;
int buttonState = 0;
int a = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
  if (buttonState == HIGH) {
    if (a == 0) {
     a = 1;
     digitalWrite(ledPin, HIGH);
    }else {
     a = 0;
     digitalWrite(ledPin, LOW);
The problem is noise from button during switching and speed of the program - it is too fast. You need something for button debouncing. There is HW or SW solution. HW with Schmitt trigger. SW with debouncing algorithm - simply ignore changes on I/O which occur too fast. There is plenty libraries for it on the internet search for button debouncing.
First one:
This is it! Now button works perfect. Thanks!
I have one more issue and I dont want to add a new topic. Button works fine when arduino is only looking for digital read of my remote but right now I add a blink with delay(1000). Now when I push button I have to wait a bit for turn light on. There must be a way for those two other functions to do in the same time without waiting. How can I do something like this?
const int ledPin = 13;  //led for remote
const int ledPin2 = 11;  //led for blink
int ledState = LOW;
int buttonState;
int lastButtonState = LOW;
long lastDebounceTime = 0;
long debounceDelay = 50;
  digitalWrite(ledPin, ledState);
  digitalWrite(ledPin2, HIGH);
  digitalWrite(ledPin2, LOW);
  int reading = digitalRead(buttonPin);
  if (reading != lastButtonState) {
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (reading != buttonState) {
      buttonState = reading;
        ledState = !ledState;
  lastButtonState = reading;
Study the Blink without delay example that comes with the IDE, or this thread for how to do that.
Thanks it's working! :)
What is more important, transmitter or receiver? I'm using this set: http://botland.com.pl/moduly-radiowe/1733-modul-radiowy-4-kanaly-315-mhz-pilot.html and I have a problem with signal. When I take remote very close to receiver board, remote works fine but when I'm little bit further it's working from time to time. I'm wondering if I buy something more expensive/better quality it will work better? or the problem is somewhere else?
