remote control and receiver
I want to use remote control DX9 and receiver ORANGERX DSM2(binded) connect to arduino mega(with moto driver) to control a two wheel rover. when i adjust the remote control the output voltage on receiver's pins will change from 0.19V to 0.3V. but when i connect to the arduino analoge pins and write a program to read and print the voltage, the output never follow the remote control.
this is the program i write. even if i dont adjust the remote control the output also keep changing. what should i do
// the setup routine runs once when you press reset: void setup() { // initialize serial communication at 9600 bits per second: Serial.begin(9600); }
// the loop routine runs over and over again forever: void loop() { // read the input on analog pin 0: int sensorValue1 = analogRead(A8); int sensorValue2 = analogRead(A9); int sensorValue3 = analogRead(A10); int sensorValue4 = analogRead(A11); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V): // print out the value you read: Serial.println(sensorValue1); Serial.println(sensorValue2); Serial.println(sensorValue3); Serial.println(sensorValue4); Serial.println("end"); delay(1000); }
We're trying to help you with this already on your original thread: http://forum.arduino.cc/index.php?topic=464882 Why don't you respond there instead of cross-posting? Even worse you ignored my request for you to use code tags. REPORTED
