I used an IR remote control I bought to create a light show, totally customizable via the remote.
Arduino infrared remote control light show
Programmed by Dr. John Liu
Revision: 05/20/2011
Free software for educational and personal uses.
No warrantee!
Commercial use without authorization is prohibited.
Find details of my libraries and hardware or contact Dr. Liu at
http://liudr.wordpress.com/
All rights reserved.
Dependent library:
Ken Shirriff's IRremote library
#include <IRremote.h>
#define myClockPin 10 // The clock pin for the shift registers
#define myLatchPin 11 // The latch pin for the shift registers
#define myDataPin 12 // The data pin for the shift registers
int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
pinMode(myDataPin,OUTPUT);
pinMode(myClockPin,OUTPUT);
pinMode(myLatchPin,OUTPUT);
irrecv.enableIRIn(); // Start the receiver
static byte last; // Stores last decoded result in case the remote control sends repeat code.
static byte current; // Stores a number to be displayed on the leds. This has nothing to do with IR remotes.
static boolean forward_dir=true, run=false, mirror=false;
if (irrecv.decode(&results))
byte ret=find_key(results.value);
if (ret==254) last=254; // flush last key with invalid if invalid input is detected in case invalid remote sends out 0xffffffff that triggers repeat.
else // For valid for this remote
if ((ret==255)&&(last!=254)) ret=last; // Make sure last key was not invalid before doing repeat.
else last=ret;
switch (ret)
case '0':
current=0;
case '1':
current=1;
case '2':
current=B11;
case '3':
current=B111;
case '4':
current=B1111;
case '5':
current=B11111;
case '6':
current=B111111;
case '7':
current=B1111111;
case '8':
current=B11111111;
case 'C':
current++;
case 'c':
current--;
case 'R':
current=~current;
case 'P':
if (current==0) current=255;
else current=0;
run=false;
mirror=false;
case 'v':
current=(current>>1)|(B10000000*(bitRead(current,0)));
case 'V':
current=(current<<1)|(bitRead(current,7));
case 'L':
forward_dir=!forward_dir;
case 'T':
run=!run;
case 'A':
mirror=!mirror;
updateLed(current);
irrecv.resume(); // Receive the next value
if (run)
if (forward_dir)
updateLed(current);
if (mirror)
current=~current;
updateLed(current);
delay(100);
char find_key(unsigned long code)
const char codes[]="ML1470ST258-Iv369APVUCcR";
byte col, row, temp;
if (code==0xffffffff) return (255); // Repeat
else if ((code&0xffff0000)==0x40bf0000)
temp=lowByte((code-0x40BF00FF)/0x7f8)<<3;
for (byte i=0;i<8;i++)
bitWrite(col,i,bitRead(temp,7-i));
row=col>>2;
col=col&B11;
return (codes[col*6+row]);
else return 254; // Invalid code. Not from this remote control.
void updateLed(unsigned char first8) // Updates LED status using shift registers.
digitalWrite(myLatchPin, LOW); // Disable update to the output buffers.
shiftOut(myDataPin, myClockPin, LSBFIRST, first8);//MSBFIRST when flat LSBFIRST when standing.
digitalWrite(myLatchPin, HIGH); // Enable update to the output buffers.
