Remote Control Stepper Question
I am trying to control a stepper motor with a remote control that sends a E0E040BF hex code when pressing the power button. The motor is supposed to move whenever I press the power button, but nothing is happening. I am not getting any error codes. Here is the code:
]#include <IRremote.h>
#include <Stepper.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
int stepIN1Pin = 8;
int stepIN2Pin = 9;
int stepIN3Pin = 10;
int stepIN4Pin = 12;
int stepsPerRevolution = 20;
Stepper myStepper(stepsPerRevolution,
                  stepIN1Pin, stepIN3Pin,
                  stepIN2Pin, stepIN4Pin);
    // set the RPM
    myStepper.setSpeed(6);
     irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) {
    Serial.print(results.value,HEX);
    if(results.value == 0xE0E040BF
      myStepper.step(stepsPerRevolution);
    // wait a second
    irrecv.resume(); // Receive the next value
  delay(100);
Is it printing the correct hex code to your serial monitor? What board are you using?
I am using the OSEPP Uno. The only one Fry's had :expressionless:
Two questions, one answer is the wrong ratio.
Without the IR connected, and no IR code, does the stepper move?
PaulS:
Yes, the stepper moves.
You still haven't answered this question.
