Remote Control
hi everyone
sorry that the code is without comments
but i only copied that 1:1 and it’s gonna to compile but is not working by pressing 1 to put the led on and 2 to put it off
#include <IRremote.h>
const int RECV_PIN = 11; // the pin the IR receiver is connected to
int ledPin = 13;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn();
pinMode (ledPin, OUTPUT);
if (irrecv.decode(&results)) {
Serial.println(results.value, DEC);
if (results.value == 16724175)
  digitalWrite (13, HIGH);
if (results.value == 16718055)
{digitalWrite (13, LOW);
irrecv.resume();
First, use Ctrl-T in the IDE before you post your code...your style is difficult to read.
Second, what are these magic numbers all about:16724175 and 16718055? I assume they are some kind of signal value or something. If so, make them more readable with something like:
#define TURNON    16724175
#define TURNOFF   16718055
// more code...
   if (results.value == TURNON)
// more code
Such things makes your code easier to read.
ok
this values are the values if you press the button 1 or 2
int ledPin = 13;
    if (results.value == TURNOFF)
    { digitalWrite (13, LOW);
    irrecv.resume();
@econjack I think you posted the answer in the wrong thread. but if you
remove the both files in the following folder too
"Removing the files - libraries\RobotIRremote\IRremoteTools.cpp and libraries\RobotIRremote\IRremoteTools.h"
then it should be fine and should compile
OK, then I’d change them to:
#define BUTTON1   16724175
#define BUTTON2   16718055
#define LEDPIN       13
    if (results.value == BUTTON1)
      digitalWrite (LEDPIN, HIGH);
    if (results.value == BUTTON2)
       digitalWrite (LEDPIN, LOW);
    irrecv.resume();
Also, you defined ledpin, but never use it. You could change it as shown above. Also, you define RECV_PIN, but never use it. I have a feeling something’s missing here, as you need to probably read that pin before you can react to it.
Ok, as i mentioned, this is a copied code.
but ledPin it is used in pinmode()
and RECV_PIN in 8th line
and i don’t know what is missing cause this all is from here
http://funduino.de/index.php/3-programmieren/nr-11-fernbedienung
it’s german sorry, but the supplemented code with the led mode is in the end of the page
I ended up downloading and installing the library again. I then copied all of the extracted files into a new library directory named IRremote. For my system, this is:
E:\Arduino1.6.5\libraries\IRremote
The new library has a bunch of *.cpp files that appear to be code for various remote control devices. After the new library was installed, it compiled correctly.
econjack: I ended up downloading and installing the library again. I then copied all of the extracted files into a new library directory named IRremote. For my system, this is:
my program is also compiling correctly but it does not work. i have tested the remote controlls working with my camera. battery is not empty and so the remote control is working. once the receiver for the Rcontrol was so hot, that i couldn't touch it very long. could it be that i connected the wires wrong and the receiver is now damaged? how can i test that?
hello arduino guys :)
could somebody help me with the question above? maybe my receiver is damaged?
Run the example code that comes with the IR library.
