I have built an remote controlled car which sends signals from remote to car via nrf24l01 using an anlog joystick I have coded the transmitter and receiver code. Everything works fine, it moves forward, backward, left and right but the problem I get is that when the joystick is at resting or normal position the 2 motors connected to the motor driver l298n rotate forward for half a second then stop then rotate forward for half a second then stop, it continuosly does that. The values for restiong position is 518 or 517, 502 What do I do?
Transmitter code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9,10); //CE, CSN
const byte address[] = "12345";
void setup(){
radio.begin();
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_LOW);
void loop(){
int xValue = analogRead(A0);
int yValue = analogRead(A1);
radio.write(&xValue, sizeof(xValue));
radio.write(&yValue, sizeof(yValue));
delay(100);
Receiver Code
#include <SPI.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const int enA = A0;
const int enB = A1;
const int in1 = 2;
const int in2 = 3;
const int in3 = 4;
const int in4 = 5;
radio.begin();
radio.openReadingPipe(1, address);
radio.startListening();
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
Serial.begin(9600); // Initialize Serial communication at a baud rate of 9600
int xValue;
int yValue;
if (radio.available()) {
radio.read(&xValue, sizeof(xValue));
radio.read(&yValue, sizeof(yValue));
int restingThreshold = 30;
// Implement a deadzone for joystick values
if (abs(xValue - 517) <= restingThreshold && abs(yValue - 502) <= restingThreshold) {
xValue = 517; // Set it to the center value
yValue = 502; // Set it to the center value
Serial.print("xValue: ");
Serial.print(xValue);
Serial.print(", yValue: ");
Serial.println(yValue);
// Define the range for joystick values to stay still
if (xValue >= 512 && xValue <= 517 && yValue >= 498 && yValue <= 502) {
// Motors stay still
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
analogWrite(enA, 0);
analogWrite(enB, 0);
// Control the motors based on joystick position
if (xValue >= 510 && xValue <= 518) {
if (yValue >= 0 && yValue <= 8) { // Forward
digitalWrite(in2, HIGH);
digitalWrite(in3, HIGH);
analogWrite(enA, 255);
analogWrite(enB, 255);
else if (yValue >= 1018 && yValue <= 1026) { // Backward
digitalWrite(in1, HIGH);
digitalWrite(in4, HIGH);
else {
// Motors stay still if joystick is not in a recognized position
else if (xValue >= 1018 && xValue <= 1023) { // Right
else if (xValue >= 0 && xValue <= 498) { // Left
