To get me familiar with the OPLA Kit. I am using the Smart Garden project. I find that the Remote IoT app works well in turning ON/OFF all the Outputs. However, if the app is not used for a while or I start it after a few minutes. The Remote IoT app does not reflect the actual Output Status. Any feedback?
That is controlled by your code. It is in the lines below??? OOPS I cannot see it. Post your code following forum guidelines and also post a Schematic of how you have it wired.
THIS IS THE CODE:
This is a smaller version of the Smart Garden Code provided in the OPLA website. I just chopped what I did not need. I'm planning (or are in the process) to add additional code. But I stopped because sometime the Dashboard does not reflect the real Pump State. It always controls it but some times fails to reflect its stage.
I hop you can help me. Thank thank !
// LIBRARIES
#include "thingProperties.h"
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
//DEFENITIONS
int water_level_Pin = A5; //The Capasitive water sensor is connected to Analo Input 5
int raw_water_level; // This is the variable to hold the raw number from the Analog Input 5. 0 to 1023
bool start_monitor; // This is a ON/OFF selector switch from the Dashboard to start monitoring the Tray Filling
// and to start the timer to keep track of the time it takes for the tray to get full.
String waterPumpState; // This variable checkS whether the Ralay2 is CLOSED or OPEN, so it can be displayed on the dashboard
uint32_t lightsOn = carrier.leds.Color(82, 118, 115); // This set the color of the LEDs when ON
uint32_t lightsOff = carrier.leds.Color(0, 0, 0); // This set the colod of the LEDs when OFF
// COMMUNICATION INITIALIZATION
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
//Get Cloud Info/errors , 0 (only errors) up to 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
//Wait to get cloud connection to init the carrier
while (ArduinoCloud.connected() != 1)
ArduinoCloud.update();
CARRIER_CASE = true;
carrier.begin();
carrier.display.setRotation(2);
delay(1500);
// MAIN LOOP
//Update the Cloud
//read raw_water_level value
int raw_water_level = analogRead(water_level_Pin);
int waterlevel;
//map raw_water_level to a scale of 0 - 100
water_Level = map(raw_water_level, 0, 1023, 100, 0);
delay(100);
void onWaterpumpChange() {
if (water_Pump == true) {
carrier.Relay2.open();
waterPumpState = "PUMP: ON";
carrier.Relay2.close();
waterPumpState = "PUMP: OFF";
updateScreen();
//Update displayed Info
void updateScreen()
carrier.display.fillScreen(ST77XX_RED);
carrier.display.setTextColor(ST77XX_WHITE);
carrier.display.setTextSize(3);
carrier.display.setCursor(40, 50);
carrier.display.print(waterPumpState);
Since WaterPump is READ_WRITE variable, onWaterPumpChange() is
executed every time a new value is received from IoT Cloud.
void onWaterPumpChange() {
// Add your code here to act upon WaterPump change
THIS THE CODE PRODUCED BY THE ARDUINO IoT CLOUD
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char SSID[] = SECRET_SSID; // Network SSID (name)
const char PASS[] = SECRET_PASS; // Network password (use for WPA, or use as key for WEP)
void onWaterPumpChange();
int water_Level;
bool water_Pump;
void initProperties(){
ArduinoCloud.addProperty(water_Pump, READWRITE, ON_CHANGE, onWaterPumpChange);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
Further more......
More indication that this Arduino IoT Cloud is not reliable AT ALL!
In the Dashboard I have two switches , on of them is Bool/water_Pump. This selector switch was not touched a single time during the evening. Look how the stage of the switch changes randomly during the night all by itself!
time | value |
2022-10-05T00:05:56.48Z | TRUE |
2022-10-05T00:06:51.077Z | FALSE |
2022-10-05T00:06:53.463Z | FALSE |
2022-10-05T00:14:23.111Z | TRUE |
2022-10-05T00:16:06.27Z | TRUE |
2022-10-05T00:18:00.957Z | TRUE |
2022-10-05T00:21:39.109Z | TRUE |
2022-10-05T00:23:11.462Z | FALSE |
2022-10-05T00:23:13.645Z | FALSE |
2022-10-05T00:23:48.185Z | TRUE |
2022-10-05T00:23:49.299Z | FALSE |
2022-10-05T00:23:51.307Z | FALSE |
2022-10-05T00:58:46.682Z | TRUE |
2022-10-05T00:58:49.664Z | TRUE |
2022-10-05T00:58:52.553Z | FALSE |
2022-10-05T00:58:55.11Z | FALSE |
2022-10-05T00:59:07.639Z | TRUE |
2022-10-05T00:59:09.846Z | TRUE |
2022-10-05T01:13:43.867Z | FALSE |
2022-10-05T01:16:01.774Z | FALSE |
2022-10-05T01:17:29.984Z | FALSE |
2022-10-05T01:19:23.235Z | TRUE |
2022-10-05T01:19:25.937Z | TRUE |
2022-10-05T01:24:37.808Z | FALSE |
2022-10-05T01:24:39.783Z | FALSE |
2022-10-05T01:24:54.362Z | FALSE |
2022-10-05T01:26:33.676Z | FALSE |
2022-10-05T01:44:15.869Z | FALSE |
2022-10-05T01:44:59.704Z | TRUE |
2022-10-05T01:45:03.255Z | TRUE |
2022-10-05T01:45:03.833Z | FALSE |
2022-10-05T01:45:05.954Z | FALSE |
2022-10-05T02:17:55.043Z | TRUE |
2022-10-05T02:17:56.191Z | FALSE |
2022-10-05T02:19:39.35Z | TRUE |
2022-10-05T02:45:46.225Z | FALSE |
2022-10-05T02:45:46.684Z | FALSE |
2022-10-05T02:45:56.19Z | TRUE |
2022-10-05T02:45:58.357Z | TRUE |
2022-10-05T03:09:19.835Z | TRUE |
2022-10-05T03:09:30.753Z | FALSE |
2022-10-05T03:09:32.852Z | FALSE |
2022-10-05T03:12:55.862Z | TRUE |
2022-10-05T03:12:57.805Z | TRUE |
2022-10-05T12:32:51.302Z | FALSE |
2022-10-05T12:32:53.083Z | TRUE |
2022-10-05T12:32:53.45Z | FALSE |
2022-10-05T12:32:55.043Z | TRUE |
2022-10-05T13:06:16.719Z | TRUE |
This is crazy!
Any feedback???
