Remote IOT microcontrollers with sim card ?
Say I need to deploy IOT systems in remote areas.... ( as in far from the cities )
would be best to use microcontrollers that works effortlessly with sim cards ? ( for connection )
If that's the case, which boards would you recommend. ? ( arduino and others )
Will those areas have cellular coverage?
Only if the intended areas have cellular coverage.
If they do have coverage, what type is it: 4G? 5G? NB-IoT? Cat-M? Other??
Your topic has been moved to a suitable location on the forum. Please read the sticky topics in Uncategorized - Arduino Forum to understand why you should not post in "Uncategorized".
it is worth considering lora which is designed for long distance communication ? see lora gateway map
you may need to visit the potential sites to check coverage, e.g. cellular, lora, etc
if no coverage is there a possible site for a Lora gateway?
