Remote IR thermometer sensor
Hi all,
I'm looking for a sensor or a module to use with arduino to take temperature from distant objects. I've found this sensor MLX90614, it do all I need, also without elaborations(it have on board mcu), but as I see on reviews it can work only at aprox. 2cm.
I need something between 5cm and 10cm(longer range is better). But all sensor I've found are all "Professional" and price is very high.
My temperature range is between 0° to 260/300°.
Do you have any advice?
Thank you!
Not true. The MLX90614 reports the average temperature of the entire field of view, and is not limited by distance.
you need a lens
