Remote Light switching
I'm new to Arduino but I have an electronics and communications background. I have a need to develop a remote controlled light switching device. Has anyone tinkered in this area. I'm interested to know if it is achievable.
Ian
Fully. What "remote" do you plan to use (i.e.: smart phone, remote -TV set type-, dedicated item, long distance switch,. . . .)?
What distance do you want to cover?
Regards
vffgaston:
Also, what kind of light is it? Mains, low voltage, arc light, LED, filament, fluorescent, etc.?
Do you just want to switch it on/off or do you also want to dim it?
Look into [u]Home Automation[/u]. I've had an [u]X-10[/u] based system for many years. I've got about 10 lights and devices that are controlled by a programmed master timer or with remote controllers.
I can't control my stuff over the Internet or cell phone, but a controller for that could be easily added.
I didn't build any of this stuff myself, but it's possible to build a controller that's compliant with X-10 or one of the other standard protocols if you want to. I wouldn't recommend building your own wall switches because there are "complications" that make that tricky.
there are devices from smarthome that use a protocol called X-10
you can use the Arduino to control things on this X-10
I googled Arduino and X-10 to get this
"This library has been tested using the PL513 one-way X10 controller, and the TW523 two-way X10 controller. Both of these are essentially X10 modems, converting the 5V output of the Arduino into AC signals on the zero crossing."
