Pretty new to Arduino here.. I have a Mega256 with a W5100 shield. I have a sketch working on it and I am tweeking it every so often. Rather than go into the basement and hook up a USB cable to upload a ew sketch, is there a way I can do it using the network and the Arduino IDE that I use to upload over USB?
Thanks I will check it out. Is there any way to use the Arduino IDE to do this remotely? It seems like it would be a much easier way. Just a noob opinion.
edlentz:
I don't understand your question... are you asking the same one again?
the board is programmed through USB (or ISP). basic Arduinos don't have any wireless capabilities - so if you don't want a long cable to go to your board, you need to add something doing the wireless stuff for you.
other types of "arduinos" based on ESP for example have wifi built-in and once programmed you can have some code in your solution to handle OTA updates
