I operate a fish farm in a remote area. No cellular connection. I have an intake pipe in our lake about 800m away from the hatchery. The hatchery and lake are not line of sight, the lake is about 100m higher elevation. I would like to add a depth sensor and temp sensor to the pipeline to monitor the depth and temp from the hatchery. I have the sensors I want to use picked out, but don't know the best method to transmit the data to an oled at the hatchery.
Suggestions?
For the temp sensor I plan to use a DS18B20
and for the depth sensor I am planning on the DFRobot Gravity Liquid level transmitter
I have 12v dc (solar) available at the intake
You might consider a pair of RFM69HW-915 radio's. I had a short foray into "mysensors.org" and tested a pair of radios that easily went a couple of 100 meters with objects in the path. (houses, concrete wall etc)
There was some discussion of a longer range radio which I don't recall.
Hello,
take two HC-12 transceivers and Arduinos including a simple ping-pong sketch and test the propagation conditions. Take care about the line of sight for the arials.
Good luck.
Thank you all for your responses! I was considering a LoRa setup, your responses confirm this is probably my best method. I had not considered using a mesh network to achieve my distance goal if needed. I think I have my hardware sorted out now! Thank you all!!!
