Remotexy How to assign 2 pin out for every button press
I'm a Noob, please help
I'm using remotexy, I have 10 buttons that will control 8 relays, I'm trying to figure out how to control combination of 2 pin output for every button that is press, for example button 1, when press would set pin out 2 and 4 HIGH and button 2 would, when press would set pin out 1 and 8 HIGH. When buttons are release the pin out would return to LOW.
here is my code
   -- project2 --
   This source code of graphical user interface
   has been generated automatically by RemoteXY editor.
   To compile this code using RemoteXY library 2.3.3 or later version
   download by link http://remotexy.com/en/library/
   To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
     - for ANDROID 4.1.1 or later version;
     - for iOS 1.2.1 or later version;
   This source code is free software; you can redistribute it and/or
   modify it under the terms of the GNU Lesser General Public
   License as published by the Free Software Foundation; either
   version 2.1 of the License, or (at your option) any later version.
//        RemoteXY include library          //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__HARDSERIAL
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL Serial
#define REMOTEXY_SERIAL_SPEED 9600
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
  { 255,9,0,0,0,94,0,8,13,0,
  1,0,13,6,12,12,2,31,49,0,
  1,0,29,6,12,12,2,31,50,0,
  1,0,58,6,12,12,2,31,52,0,
  1,0,44,6,12,12,2,31,51,0,
  1,0,74,7,12,12,2,31,53,0,
  1,0,13,24,12,12,2,31,55,0,
  1,0,30,24,12,12,2,31,56,0,
  1,0,45,24,12,12,2,31,57,0,
  1,0,61,24,12,12,2,31,49,48,
  0 };
// this structure defines all the variables of your control interface
struct {
    // input variable
  uint8_t button_1; // =1 if button pressed, else =0
  uint8_t button_2; // =1 if button pressed, else =0
  uint8_t button_3; // =1 if button pressed, else =0
  uint8_t button_4; // =1 if button pressed, else =0
  uint8_t button_5; // =1 if button pressed, else =0
  uint8_t button_6; // =1 if button pressed, else =0
  uint8_t button_7; // =1 if button pressed, else =0
  uint8_t button_8; // =1 if button pressed, else =0
  uint8_t button_9; // =1 if button pressed, else =0
    // other variable
  uint8_t connect_flag;  // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
//           END RemoteXY include          //
#define PIN_BUTTON_1 2
#define PIN_BUTTON_2 3
#define PIN_BUTTON_3 4
#define PIN_BUTTON_4 5
#define PIN_BUTTON_5 6
#define PIN_BUTTON_6 7
#define PIN_BUTTON_7 8
#define PIN_BUTTON_8 9
#define PIN_BUTTON_9 10
  RemoteXY_Init ();
  pinMode (PIN_BUTTON_1, OUTPUT);
  pinMode (PIN_BUTTON_2, OUTPUT);
  pinMode (PIN_BUTTON_3, OUTPUT);
  pinMode (PIN_BUTTON_4, OUTPUT);
  pinMode (PIN_BUTTON_5, OUTPUT);
  pinMode (PIN_BUTTON_6, OUTPUT);
  pinMode (PIN_BUTTON_7, OUTPUT);
  pinMode (PIN_BUTTON_8, OUTPUT);
  pinMode (PIN_BUTTON_9, OUTPUT);
  // TODO you setup code
  RemoteXY_Handler ();
  digitalWrite(PIN_BUTTON_1, (RemoteXY.button_1==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_2, (RemoteXY.button_2==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_3, (RemoteXY.button_3==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_4, (RemoteXY.button_4==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_5, (RemoteXY.button_5==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_6, (RemoteXY.button_6==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_7, (RemoteXY.button_7==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_8, (RemoteXY.button_8==0)?LOW:HIGH);
  digitalWrite(PIN_BUTTON_9, (RemoteXY.button_9==0)?LOW:HIGH);
  // TODO you loop code
  // use the RemoteXY structure for data transfer
using this formula, "digitalWrite(PIN_BUTTON_9, (RemoteXY.button_9==0)?LOW:HIGH);", is there a syntax for digitalWrite that would allow me to assign more than one pin_button?
So how far did you get ? please remember to use </> code-tags for posting code and include a wiring diagram. Pressing and releasing a button (or pressing after a button was released) should conditionally execute some part of your code, where you can set pins high or low.
im trying to do this too, i think that this page on remoteXY's website could help:
i think that this code from the website could help
if (RemoteXY.button_1!=0) {
/* button pressed /
else {
button not pressed */
