RemoteXY tank code doesn't work
I’m trying to figure out why my code doesn’t work. It’s for controlling a RC tank with proportional control for each track with the RemoteXY app and the hm-10 ble module. I’m using Arduino UNO R3 and for the motors l298N bridge.
I can connect to the board with bluetooth and I do get the GUI, but when i move the sliders, nothimg happens.
//        RemoteXY include library          //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__HARDSERIAL
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL Serial
#define REMOTEXY_SERIAL_SPEED 9600
#define REMOTEXY_ACCESS_PASSWORD "0000"
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
  { 255,2,0,0,0,19,0,10,24,0,
  4,48,19,3,10,58,33,26,4,48,
  72,4,10,57,33,26 };
// this structure defines all the variables and events of your control interface
struct {
    // input variables
  int8_t slider_1; // =-100..100 slider position
  int8_t slider_2; // =-100..100 slider position
    // other variable
  uint8_t connect_flag;  // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
//           END RemoteXY include          //
  int pos1 = RemoteXY.slider_1;
  int pos2 = RemoteXY.slider_2;
/*  pos equal to the position of the slider, changing from 0 to 100 */
  const int IN1_L = 8;
  const int IN2_L = 9;
  const int IN1_R = 4;
  const int IN2_R = 3;
  const int DIR_L = 10;
  const int DIR_R = 5;
  RemoteXY_Init ();
pinMode (DIR_L, OUTPUT);
pinMode (DIR_R, OUTPUT);
/* speed control pins */
  pinMode (IN1_L, OUTPUT);
  pinMode (IN2_L, OUTPUT);
  pinMode (IN1_R, OUTPUT);
  pinMode (IN2_R, OUTPUT);
  RemoteXY_Handler ();
  int pos = RemoteXY.slider_1;
  if (pos1>0) { // up
    digitalWrite(IN1_L, HIGH);
    digitalWrite(IN2_L, LOW);
    analogWrite(DIR_L, pos * 5.11);
  else if (pos1<0) { // down
    digitalWrite(IN1_L, LOW);
    digitalWrite(IN2_L, HIGH);
    analogWrite(DIR_L, (0-pos) * 5.11);
  else { // stop
    analogWrite(DIR_L, 0);
/* speed and direction control for left track */
  if (pos1>0) { // up
    digitalWrite(IN1_R, HIGH);
    digitalWrite(IN2_R, LOW);
    analogWrite(DIR_R, pos * 5.11);
    digitalWrite(IN1_R, LOW);
    digitalWrite(IN2_R, HIGH);
    analogWrite(DIR_R, (0-pos) * 5.11);
  else { // stop
    analogWrite(DIR_R, 0);
  // speed and direction control for right track
  // use the RemoteXY structure for data transfer
  // do not call delay()
#define REMOTEXY_SERIAL_SPEED 9400
A normal baud rate is 9600. Are you sure about this? Also what hardware testing have you done? Did you try running a simple test sketch to just run the motors without any remote?
Tell us about pos1 and pos2
TheMemberFormerlyKnownAsAWOL:
pos1 is for knowing the position of the slider1. In my case I have 2 sliders so i have pos1 and pos2 for each slider
And where are they updated?
What do you mean? The command is in the void loop section; isn't it supposed to always update?
Maybe we’re looking at different code.
Guys nevermind i managed to make it work. Turns out i forgot to specify pos1 and pos2 in the void loop section for the sliders. Now it works.
Thanks anyway for the time
