Hello
I am a beginner.
My mini project is an ==> anemometer+xbee s2c+arduino (router) & LCD+xbee s2c+arduino (coordinator).
the two xbee is talking to each other very well, but the problem is in programming the two arduino to display the sensor value/ alert when it ecxeding a certain wind speed.
Router code
This code takes the output from an anemometer and converts it into a wind speed.
#include <Wire.h>//Setup Variables
const int sensorPin = A0; //Defines the pin that the anemometer output is connected to
int sensorValue = 0; //Variable stores the value direct from the analog pin
float sensorVoltage = 0; //Variable that stores the voltage (in Volts) from the anemometer being sent to the analog pin
float windSpeed = 0; // Wind speed in meters per second (m/s)float voltageConversionConstant = .004882814; //This constant maps the value provided from the analog read function,
//which ranges from 0 to 1023, to actual voltage, which ranges from 0V to 5V
int sensorDelay = 1000; //Delay between sensor readings, measured in milliseconds (ms)//Anemometer Technical Variables
//The following variables correspond to the anemometer sold by Adafruit, but could be modified to fit other anemometers.float voltageMin = .4; // Mininum output voltage from anemometer in mV.
float windSpeedMin = 0; // Wind speed in meters/sec corresponding to minimum voltagefloat voltageMax = 2.0; // Maximum output voltage from anemometer in mV.
float windSpeedMax = 32; // Wind speed in meters/sec corresponding to maximum voltagevoid setup()
Serial.begin(9600); //Start the serial connection
}void loop()
sensorValue = analogRead(A0); //Get a value between 0 and 1023 from the analog pin connected to the anemometersensorVoltage = sensorValue * voltageConversionConstant; //Convert sensor value to actual voltage
//Convert voltage value to wind speed using range of max and min voltages and wind speed for the anemometer
if (sensorVoltage <= voltageMin){
windSpeed = 0; //Check if voltage is below minimum value. If so, set wind speed to zero.
}else {
windSpeed = (sensorVoltage - voltageMin)*windSpeedMax/(voltageMax - voltageMin); //For voltages above minimum value, use the linear relationship to calculate wind speed.
//Print voltage and windspeed to serial
Serial.print("Time: ");
Serial.println(millis());
Serial.print("Wind speed: ");
Serial.println(windSpeed);
delay(sensorDelay);
Coordinator Code
delay(1000);//enter AT mode finish
while(Serial.available()>0){
Serial.write(Serial.read());
}}void loop(){
delay(750);//3/4 a sec
