Serial.print("anything you want to print 0b");
Serial.println(input, BIN);
Serial.print("again, any prefix you desire 0b");
Serial.println(input >> 6, BIN);
Note that there is no such thing as a 26 bit variable in C/C++ but you can choose to only use any range of bits within a variable and ignore the rest if that is what you want
uint32_t input = 0b00111100111110100010010100000011;
printBin(input, 31, 0);
printBin(input, 31, 6);
void printBin(uint32_t number, int start, int end)
for (int b = start; b >= end; b--)
Serial.print(bitRead(number, b));
Actually I am reading the bit from HID reader and I want if the reading is 26 bit will send it out as wiegand value but if 32 i want to remove last 6 bit to make it 26 bit then send it out as wiegand number.
#define MAX_BITS 100 // max number of bits
#define WEIGAND_WAIT_TIME 3000 // time to wait for another weigand pulse.
unsigned char databits[MAX_BITS]; // stores all of the data bits
unsigned char bitCount; // number of bits currently captured
unsigned char flagDone; // goes low when data is currently being captured
unsigned int weigand_counter; // countdown until we assume there are no more bits
unsigned long facilityCode=0; // decoded facility code
unsigned long cardCode=0; // decoded card code
int LED_GREEN = 11;
int LED_RED = 12;
int BEEP_BEEP = 10;
// interrupt that happens when INTO goes low (0 bit)
void ISR_INT0() {
bitCount++;
flagDone = 0;
weigand_counter = WEIGAND_WAIT_TIME;
// interrupt that happens when INT1 goes low (1 bit)
void ISR_INT1() {
databits[bitCount] = 1;
bitCount++;
flagDone = 0;
pinMode(LED_RED, OUTPUT);
pinMode(LED_GREEN, OUTPUT);
pinMode(BEEP_BEEP, OUTPUT);
digitalWrite(LED_RED, HIGH); // High = Off
digitalWrite(BEEP_BEEP, HIGH); // High = off
digitalWrite(LED_GREEN, LOW); // Low = On
//Make sure the mode is INPUT_PULLUP for Software House SWH 5100 Model.
pinMode(2, INPUT_PULLUP); // DATA0 (INT0)
pinMode(3, INPUT_PULLUP); // DATA1 (INT1)
Serial.println("RFID Readers");
// binds the ISR functions to the falling edge of INTO and INT1
attachInterrupt(0, ISR_INT0, FALLING);
attachInterrupt(1, ISR_INT1, FALLING);
// This waits to make sure that there have been no more data pulses before processing data
if (!flagDone) {
if (--weigand_counter == 0)
flagDone = 1;
// if we have bits and we the weigand counter went out
if (bitCount > 0 && flagDone) {
unsigned char i;
Serial.print("Raw Binary = ");
for (i=0; i<bitCount; i++)
Serial.print(databits[i]);
Serial.print("\nBits = ");
Serial.print(bitCount);
if (bitCount == 32) {
Serial.print(databits[i]-6);
//Serial.println(databits[i], BIN);
//Serial.println(databits[i] >> 6, BIN);
if (bitCount == 35) {
Serial.print("\nCard format: HID Corporate 1000");
// facility code = bits 2 to 14
for (i=2; i<14; i++) {
facilityCode <<=1;
facilityCode |= databits[i];
// card code = bits 15 to 34
for (i=14; i<34; i++) {
cardCode <<=1;
cardCode |= databits[i];
printBits();
else if (bitCount == 26) {
Serial.print("\nCard format: Standard 26 bit format");
// facility code = bits 2 to 9
for (i=1; i<9; i++) {
facilityCode <<=1;
// card code = bits 10 to 23
for (i=9; i<25; i++) {
cardCode <<=1;
printBits();
else if (bitCount == 40) {
Serial.print("\nCard format: Casi-Rusco 40 Bit");
Serial.print("\n\n**************************\n\n");
}else{
// you can add other formats if you want!
Serial.print("\nUnable to decode.");
// cleanup and get ready for the next card
bitCount = 0;
facilityCode = 0;
cardCode = 0;
for (i=0; i<MAX_BITS; i++)
databits[i] = 0;
void printBits(){
Serial.print("\nFacility Code = ");
Serial.print(facilityCode);
Serial.print("\nCard Code = ");
Serial.print(cardCode);
// Now lets play with some LED's for fun:
digitalWrite(LED_RED, LOW); // Red
if(cardCode == 432279){
// If this one "bad" card, turn off green
// so it's just red. Otherwise you get orange-ish
digitalWrite(LED_GREEN, HIGH);
}else {
delay(100);
delay(100);
delay(100);
delay(100);// Red Off
delay(300);// Red Off
// Lets be annoying and beep more
digitalWrite(BEEP_BEEP, LOW);
then I will recognize which one is 32 and 26, if 26 will send it as Wiegand and if 32 I will trim the last 6 bits then send it out as Wiegand using another code
