Remove M7 Diode from UNO(r2)
hello there,
i'm using my arduino for an application where lots of LEDs that draw 1.5 A at max are in use.
my approach initially was to use a 12V power supply to power the arduino and to power the leds via the Vin port of the arduino.
after a month or so the M7 diode in front of the power regulator burned (and i found out that the diode used apparently does not take more than 1 A - which i exceeded at some point) - i learned something here.
my question is: is it safe to remove the diode and just bridge the hole? of course i would lose the protection for powering the arduino the wrong way but i could live with that. what other implications come with removing this diode?
thanks in advance for your advice!
The only other change will be that you will shift the input voltage range down by 0.7v (you will lose the 0.7V drop of the diode).
that makes sense, thank you.
but with a 12 V power supply i should be on the safe side.
You would, of course, also loose the polarity protection the diode provides.
motzi:
The MC33269 voltage regulator on the Uno R2 board is rated at 800 mA. So you will have something else burning out fairly soon.
I suggest a different approach.
I withdraw that comment, you aren't using 5V, right?
However I don't know if the tracks on the board are designed to take 1.5 amps. Maybe they are.
How are you controlling the diodes?
12V-resistor-LED-?transistor?-arduino pin?
