Reading http://arduino.cc/en/Tutorial/ArduinoToBreadboard...
I have built everything on the breadboard, using an atmega328 on the board.
I have an OSEPP UNO, based on the arduino UNO, that I would like to use to upload my sketch.
The chip on the breadboard shipped with the bootloader.
Question is, is there a somewhat universal way of disabling the microcontroller on the board when it's not removable?
I can't pull the chip off my nonstandard UNO unfortunately. Is this an easy fix?
Here's the schematic of the board I'm using if it helps... http://osepp.com/wp-content/uploads/2011/09/OSEPP_Uno_Arduino_Compatible-Rev1.1-Schematic.pdf
Ok, you want to use the OSEPP board to program the other board?
Download the Optiloader sketch into the OSEPP board.
Connect OSEPP pins D10, D11, D12, D13, +5, GND to breadboard’s Reset, D11,D12,D13, +5, Gnd
Run the sketch, it will put a bootloader on the breadboard for you.
You want to for some reason keep one of the 328’s from being active? Connect it’s reset pin to Gnd; the IO pins will then become inputs and not interfere with anything else that is connected.
If not one of those, please make your question more clear.
Thanks for your support, I really appreciate it. So from what I have been reading on the arduino.cc resources, you can wire up the arduino (or in my case the OSEPP UNO) and burn the bootloader pretty easily. The 328 chips ive purchased have the bootloader aready. My goal is to upload a sketch to the atmega to Implement it in a standalone fashion. It seemed to me like you actually have to disable the microcontroller on the board you're using to program (my OSEPP...) so it will upload to the 328? So tonight I wired everything up according to the way you upload the bootloader, and used my OSEPP board as an ISP, changed my preferences.txt to upload.using arduinoisp, and I actually think I've gotten it working. If you were in my situation, (arduino board with a non removable atmega328 or 168, how would you use it to program a separate Atmega328 or 168? I may have answered my own question by figuring it out on my own, but I haven't had the time to test it more than just running the blink sketch with some inconsistent results.
The seperate 168/328 is mounted on something else, yes?
So you are now trying to use the USB/Serial portion of the OSEPP to communicate with the seperate board.
Ground the reset pin on the OSEPP. Connect its Rx, TX, +5, GND to the other board.
Start the IDE, when it says “uploading xxxx of 32xxx bytes”, press reset on the seperate board.
I personally have an FTDI Basic
that I use to download sketches into my standalone boards. Lot less fooling around.
