remove my Delay :S
good morning world
this is my first time using C++
i think my delay is causing problems, as i understand this will stop the programs from running.
i would like to read the waterlevel all the time, so if its below low level it will make the 3 out puts (pins 10, 11, 12) LOW , and then return ;
now i have return; in 3 places after each analogRead of waterlevel
can i read code so its only once, and that at any time it get low water level.
//reads the state of water level and displays it on the screen
//define the pins
int levelPin = 1;
int alarmPin=10;
int pumpOne=11;
int pumpTwo=12;
int lowLevel=102.3; //high water level
int highLevel=920.7; //low water level
int waitTime=30000; // 30 seconds waiting time
boolean firstPump=HIGH; //declare state of the first pump too run (alternately)
//set the level pin as an input & alarm pump1 pump2 pins as output
pinMode(levelPin, INPUT);
pinMode(alarmPin, OUTPUT);
pinMode(pumpOne, OUTPUT);
pinMode(pumpTwo, OUTPUT);
//allows to listen to serial communications from the arduino
int val = analogRead(levelPin);
if(val > highLevel)
firstPump = !firstPump; //alternate first pump to run
digitalWrite(pumpOne,firstPump);
digitalWrite(pumpTwo,!firstPump);
if(val <lowLevel)
digitalWrite(pumpOne,LOW);
digitalWrite(pumpTwo,LOW);
return ;
//start second pump after 30 sec if first pump is running
delay(waitTime);
if((val > highLevel) && pumpOne == HIGH);
digitalWrite(pumpTwo, HIGH);
if((val > highLevel) && pumpTwo == HIGH);
digitalWrite(pumpOne, HIGH);
if(val <lowLevel)
return ;
//start alarm after 30 sec if pump 1 & 2 are running
delay(waitTime);
if(digitalRead((pumpOne) == HIGH)&&(pumpTwo) == HIGH);
digitalWrite(alarmPin, HIGH);
if(val <lowLevel)
digitalWrite(alarmPin,LOW);
//print the level state to a serial terminal
Serial.println(analogRead(levelPin));
//wait one second, then print again.
Hi SUV79,
Rather than putting a delay in your loop, consider using a timer like the following (really rough code):
...add at beginning of your sketch:
unsigned long startTime=0;
...in your loop, when you start your pump:
startTime = millis();
...in your loop when you want to see if time has elapsed 30 seconds:
if (millis() - startTime > 30000) do something...
ok i will look at this again, i looked at unsigned long yesterday but did not really under how it worked,
i will watch some more youtube about this :slight_smile:
thank you
if (millis() - startTime > waitTime);
do something....
