Probably posted this in the wrong place. Sorry can a mod please move this.
I have been working on a timer relay. It was supposed to have a wait(or off for a certain time) feature but now the project requirements have changed.
I used a little tutorial to get me this far in the code but now I can't figure out how to remove the time off feature.
I removed it from the menu just not from the actual code but I am having trouble figuring out where that part is.
I want the code to stop once the counter hits 0 and restart.
#include <Timer.h>
#include <Wire.h>
#include <EEPROM.h>
#include <avr/eeprom.h>
enum Context {
mainMenu,
run,
chooseVar,
setTimeOn,
setTimeOff,
// initialize the library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x3F,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
Context context;
Timer t;
boolean outState = false;
int timeLeft;
int currentEventId;
const int buttonPin = 6; // the number of the pushbutton pin
const int outputPin = 9;
int buttonState;
int lastButtonState = LOW;
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
int timeOn = 5;
int timeOff = 5;
int encoder0PinA = 8;
int encoder0PinB = 7;
int encoder0Pos = 0;
int encoder0PinALast = LOW;
int n = LOW;
int addressOn = 0;
int addressOff = 100;
int contIncr = 0;
byte arrow[8] = {
B00000,
B00100,
B00110,
B00111,
B00110,
B00100,
B00000,
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.home();
lcd.begin(16, 2);
initMainMenu();
lcd.createChar(0, arrow);
eeprom_read_block((void*)&timeOn, (void*)addressOn, sizeof(int));
eeprom_read_block((void*)&timeOff, (void*)addressOff, sizeof(int));
//timeOn = EEPROM.read(addressOn);
//timeOff = EEPROM.read(addressOff);
pinMode(buttonPin, INPUT);
pinMode (encoder0PinA,INPUT);
pinMode (encoder0PinB,INPUT);
pinMode(6, INPUT_PULLUP);
pinMode(outputPin, OUTPUT);
digitalWrite(encoder0PinA, HIGH); //turn pullup resistor on
digitalWrite(encoder0PinB, HIGH); //turn pullup resistor on
Serial.begin (9600);
void initMainMenu() {
contIncr = 0;
context = mainMenu;
lcd.clear();
lcd.print("Choose Action:");
lcd.setCursor(0,1);
lcd.write(byte(0));
lcd.print("Start Adj.Time");
void rotaryMainMenu() {
contIncr = !contIncr;
if (contIncr) {
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(7,1);
lcd.write(byte(0));
lcd.setCursor(0,1);
lcd.write(byte(0));
lcd.setCursor(7,1);
lcd.print(" ");
void buttonMainMenu() {
if (contIncr) {
initChooseVar();
initRun();
void initChooseVar() {
contIncr = 0;
context = chooseVar;
lcd.clear();
lcd.print("Change Time:");
lcd.setCursor(0,1);
lcd.write(byte(0));
lcd.print("On Back");
void rotaryChooseVar(boolean dir) {
if (dir) {
contIncr++;
contIncr--;
if (contIncr < 0) contIncr += 3;
contIncr = contIncr % 3;
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(11,1);
lcd.print(" ");
switch (contIncr) {
case 0:
lcd.setCursor(0,1);
case 1:
lcd.write(byte(0));
void buttonChooseVar() {
switch (contIncr) {
case 0:
initSetTimeOn();
case 1:
initMainMenu();
void initSetTimeOn() {
context = setTimeOn;
lcd.clear();
lcd.print("Set Time On:");
lcd.setCursor(0,1);
lcd.print(timeOn);
lcd.print("s");
void rotarySetTimeOn(boolean dir) {
if (dir) {
timeOn++;
timeOn--;
if (timeOn < 0) timeOn = 0;
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(timeOn);
lcd.print("s");
void buttonSetTimeOn() {
eeprom_write_block((const void*)&timeOn, (void*)addressOn, sizeof(int));
initChooseVar();
void initRun() {
context = run;
outState = false;
timeLeft = 0;
lcd.clear();
lcd.print("Starting!");
currentEventId = t.every(1000, refreshTime);
void refreshTime() {
if (timeLeft == 0) {
outState = !outState;
timeLeft = (outState?timeOn:timeOff) - 1;
lcd.clear();
lcd.print("Remaining ");
lcd.print(timeLeft);
lcd.print("s");
lcd.setCursor(0,1);
lcd.print("Next ");
lcd.print(!outState?"ON ":"OFF ");
lcd.print(!outState?timeOn:timeOff);
lcd.print("s");
digitalWrite(outputPin, outState?HIGH:LOW);
timeLeft--;
lcd.setCursor(6,0);
lcd.print(" ");
lcd.setCursor(6,0);
lcd.print("s");
void buttonRun() {
t.stop(currentEventId);
outState = false;
digitalWrite(outputPin, LOW);
initMainMenu();
void catchRotary() {
n = digitalRead(encoder0PinA);
if ((encoder0PinALast == LOW) && (n == HIGH)) {
boolean rotaryDir = digitalRead(encoder0PinB) == LOW;
switch (context) {
case mainMenu:
rotaryMainMenu();
case chooseVar:
rotaryChooseVar(rotaryDir);
case setTimeOn:
rotarySetTimeOn(rotaryDir);
encoder0PinALast = n;
void catchButton() {
int reading = digitalRead(buttonPin);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == HIGH) {
switch (context) {
case mainMenu:
buttonMainMenu();
case chooseVar:
buttonChooseVar();
case setTimeOn:
buttonSetTimeOn();
case run:
buttonRun();
lastButtonState = reading;
catchRotary();
catchButton();
t.update();
Also, I have an problem when the arduino starts it runs the code without any button press.
Any one see where that starts? This is the most important part.
