Removing a manually added library from the web IDE
I added a library that already exists so I have a duplication.
Any idea how to remove it? I can’t find it in the UI.
It hasn't been implemented yet, but we have mockups. I will higher the priority of it. In the meantime maybe @msuppo can remove it for you?
A workaround in the meantime is going in Preferences and check the option called ‘Show all folder content in Sketchbook’. Then if you go in your Sketchbook panel you will see your Libraries folder. From there you can cancel the folder.
