How does one remove a board from the IDE ?
By the edit of boards.txt file in ESP package directory of your Arduino IDE.
But let me ask you a question - why?
Thanks for the info. I installed it to try out the board for a friend. I will not be using it myself.
You need to clarify your question - do you want to remove only the Wemos board or whole ESP package ?
The whole ESP package would be preferable.
then you can not consider my answer above - it is to remove the mention of the board from the interface only
so... is there no way to delete the whole package?
