Removing line of code causes compilation error
When I comment out a line of code I get a compile error. Attached is the error report
digitalWrite(LED_BUILTIN, LOW);
delay(3000);
// digitalWrite(LED_BUILTIN, HIGH); <<<<<<<<<< this line.
delay(200);
thanks
Post your entire code and entire error message.
Compiles fine for me, with or without the commented line
  delay(3000);
  delay(200);
Thanks: Yes I see no reason that an error occurs.
I simply run the sketch and it works. When I remove one of the "digitalWrite(LED_BUILTIN,HIGH OR LOW)" COMPILE FAILS.
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // IF I remove either digitalWrites or Both I get a compile fail delay(2000); digitalWrite(LED_BUILTIN, LOW); // IF I remove either digitalWrites or Both I get a compile fa delay(4000);i
} ERROR ATTACHED
delay(4000);i
What is the i at the end this line?
ERROR ATTACHED
No attachment with your last post. Please try again.
Stray non-ascii whitespace, perhaps.
Zip the code into a zip file.... the one that doesn't compile (ie. zip the actual file itself) ... and upload to this thread. So we can analyse the ascii characters.
