For my second attempt with Arduino (Blink being the first), I tried combining the AnalogInput and BlinkWithoutDelay examples to make the blink speed controlled by a potentiometer. I got it working, and I had a Serial.println(interval); in there for debugging. Once I took it out, the blinking would start at the correct interval, then would quickly speed up and go constant-on (or a very small interval). With the attached code, can anybody help me? Thanks!
define potPin 2
define ledPin 13
float val = 0; float interval = 0; long previousMillis = 0; int value = LOW;
void setup() { pinMode(ledPin, OUTPUT); Serial.begin(9600); }
void loop() { //280-630 : Approxamate range of my pot val = analogRead(potPin); interval = long((((val)-270)/360)*1000); //Change the val to an interval, approx 0-1000 Serial.println(interval); //The debug line that, when removed, causes error if (millis() - previousMillis > interval) { previousMillis = millis();
if (value == LOW) value = HIGH; else value = LOW;
digitalWrite(ledPin, value); } }
