Removing Unknown Words
Can anyone enlighten me how to remove the chunk of words in the black box?
I have attached the coding I tried below:
#define ANALOG_PIN A0 // Analog pin
#define PANEL_LENGTH 60 // Length of the active part of solar panel in mm
#define PANEL_WIDTH 20 // Width of the active part of solar panel in mm
#define eff_pc 20 // per cent efficiency of solar panel
//Analog input pin assignments
#define VrefPin 3    // pin A3 - the pin our reference is connected to
#define VxPin 0       // use will use analog pin 0 for voltage x
// for voltage conversion
float vRef = 3.390; // the accurate value of your reference eg 4.096
/* *** change the value to match the reference voltage you are using  ***  */
long nX, nRef; //the value we read from the ADC
float vX;  //measured voltage values after calibration correction
// sampling parameters
int nSamp = 5;   // Number of Samples to take for each reading
int interval = 7; //milliseconds interval between successive readings
float res = 1000;  //resistance in OHMS
volatile float Area;
volatile float Power;
volatile float Radiation;
//take a set of "count" readings from selected analog input, with a delay of "pause" between readings.
long readInput(int pin, int count, int pause) {
 long n = analogRead( pin); // dummy read
 n = 0; // initialise for aggregation
 delay(pause);
 for (int i = 0; i < count; i++ ) {
   n += analogRead( pin);
   delay(pause); //short delay between readings - could use millis instead
 return n ; //returns a number count * reading
// Convert the number reading to voltage
float convReadings(long nZ, long nR, float vR)
 float ztrue = (vR * nZ) / nR; //apply correction
 ztrue*=1000; //convert to mV
 return (ztrue); //return the result as a voltage
 Main Setup function
 // Begin serial communication
 analogReference(DEFAULT);    // program is being tested on a 5V Arduino Nano so this will be ROUGHLY 5.0V; as measured on mine 4.65V
 nRef = analogRead(VrefPin); // dummy read to settle ADC Mux
 Serial.print("starting measurement - nRef is ");
 Serial.println(nRef);
 delay(5);
 Area = PANEL_LENGTH * PANEL_WIDTH; //in mm square - keep numbers big for better accuracy
 Serial.print("Area is ");
 Serial.print(Area);
 Serial.println(" uM");
 nX = readInput(VxPin, nSamp, interval);
 Serial.print("nX is ");
 Serial.print(nX);
 nRef = readInput(VrefPin, nSamp, interval);
 Serial.print(";  nRef is ");
 Serial.print(nRef);
 vX = convReadings(nX, nRef, vRef); //vX is now the measured voltage at VxPin
 Serial.print(";  Vx is ");
 Serial.print(vX, 0);
 Serial.println(" millivolts");
 Power = vX * vX / res ; // Calculating power v^2 / R in microWatts
 Power /=1000;
 Radiation = Power / Area; //mW/mm^2
 Radiation *=1000; //W/m^2
 Radiation  *= 100/eff_pc; //correct for panel efficiency
 Serial.print("Power is ");
 Serial.print(Power);
 Serial.println(" mW");
 Serial.print("Radiation is ");
 Serial.print(Radiation);
 Serial.println(" W / m2 ");
priscillayap:
By setting the data rate to 115200 baud in your serial monitor window to match your sketch?
As previously advised, please follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code and/or error messages here
arduarn:
thanks a lot appreciate it!!
