Hello,
I am working a data logger project along with bluetooth, what i need is a method to rename the files saved onto the SD card after transferring it. Currently i just remove the file usind SD.remove...
Thanks..
As far as I can tell, the library doesn't Support renaming a file. One (very inefficient) way to simulate that is to create a new file with the desired new Name, copy the Contents of the old file into the new file, and then deleting the original file.
You should also refer to Renaming Files on SD Card. Is it still impossible? - Programming Questions - Arduino Forum
