RePaper 2.0
Hi All,
I wondered if anyone had experience with the adafruit Epaper development board.
I have been trying to get it to work all day and only see a couple of very faint black lines.
What I’ve done so far :
  1. checked my wiring about 4 times
  2. changed SCREEN_SIZE 200 in the standard demo2 code
  3. tried a different MEGA
I get no errors on compiling, but with the demo2 example I get EPD error = 1
As far as I can tell this means that my COG is not supported… Since I bought the package with adfruit I don’t see how this is possible unless it is broken?
Hope someone can point me in the right direction!
this is the (standard example) code
// -*- mode: c++ -*-
// Copyright 2013 Pervasive Displays, Inc.
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at:
//   http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing,
// software distributed under the License is distributed on an
// "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either
// express or implied.  See the License for the specific language
// governing permissions and limitations under the License.
// Simple demo to toggle EPD between two images.
// Operation from reset:
// * display version
// * display compiled-in display setting
// * display FLASH detected or not
// * display temperature (displayed before every image is changed)
// * clear screen
// * delay 5 seconds (flash LED)
// * display text image
// * display picture
// * back to text display
#include <inttypes.h>
#include <ctype.h>
// required libraries
#include <SPI.h>
#include <FLASH.h>
#include <EPD2.h>
#include <S5813A.h>
// Change this for different display size
// supported sizes: 144 200 270
#define SCREEN_SIZE 200
// select two images from:  text_image text-hello cat aphrodite venus saturn
#define IMAGE_1  text_image
#define IMAGE_2  cat
// set up images from screen size2
#if (SCREEN_SIZE == 144)
#error "not yet available"
#define EPD_SIZE EPD_1_44
#define FILE_SUFFIX _1_44.xbm
#define NAME_SUFFIX _1_44_bits
#elif (SCREEN_SIZE == 200)
#define EPD_SIZE EPD_2_0
#define FILE_SUFFIX _2_0.xbm
#define NAME_SUFFIX _2_0_bits
#elif (SCREEN_SIZE == 270)
#define EPD_SIZE EPD_2_7
#define FILE_SUFFIX _2_7.xbm
#define NAME_SUFFIX _2_7_bits
#else
#error "Unknown EPB size: Change the #define SCREEN_SIZE to a supported value"
#endif
// Error message for MSP430
#if (SCREEN_SIZE == 270) && defined(__MSP430_CPU__)
#error MSP430: not enough memory
#endif
// no futher changed below this point
// current version number
#define DEMO_VERSION "1"
// pre-processor convert to string
#define MAKE_STRING1(X) #X
#define MAKE_STRING(X) MAKE_STRING1(X)
// other pre-processor magic
// tiken joining and computing the string for #include
#define ID(X) X
#define MAKE_NAME1(X,Y) ID(X##Y)
#define MAKE_NAME(X,Y) MAKE_NAME1(X,Y)
#define MAKE_JOIN(X,Y) MAKE_STRING(MAKE_NAME(X,Y))
// calculate the include name and variable names
#define IMAGE_1_FILE MAKE_JOIN(IMAGE_1,FILE_SUFFIX)
#define IMAGE_1_BITS MAKE_NAME(IMAGE_1,NAME_SUFFIX)
#define IMAGE_2_FILE MAKE_JOIN(IMAGE_2,FILE_SUFFIX)
#define IMAGE_2_BITS MAKE_NAME(IMAGE_2,NAME_SUFFIX)
// Add Images library to compiler path
#include <Images.h>  // this is just an empty file
// images
PROGMEM const
#define unsigned
#define char uint8_t
#include IMAGE_1_FILE
#undef char
#undef unsigned
PROGMEM const
#define unsigned
#include IMAGE_2_FILE
#undef char
#undef unsigned
#if defined(__MSP430_CPU__)
// TI LaunchPad IO layout
const int Pin_TEMPERATURE = A4;
const int Pin_PANEL_ON = P2_3;
const int Pin_BORDER = P2_5;
const int Pin_DISCHARGE = P2_4;
const int Pin_PWM = P2_1;
const int Pin_RESET = P2_2;
const int Pin_BUSY = P2_0;
const int Pin_EPD_CS = P2_6;
const int Pin_FLASH_CS = P2_7;
const int Pin_SW2 = P1_3;
const int Pin_RED_LED = P1_0;
#else
// Arduino IO layout
const int Pin_TEMPERATURE = A0;
const int Pin_PANEL_ON = 2;
const int Pin_BORDER = 3;
const int Pin_DISCHARGE = 4;
const int Pin_PWM = 5;
const int Pin_RESET = 6;
const int Pin_BUSY = 7;
const int Pin_EPD_CS = 8;
const int Pin_FLASH_CS = 9;
const int Pin_SW2 = 12;
const int Pin_RED_LED = 13;
#endif
// LED anode through resistor to I/O pin
// LED cathode to Ground
#define LED_ON  HIGH
#define LED_OFF LOW
// define the E-Ink display
EPD_Class EPD(EPD_SIZE, Pin_PANEL_ON, Pin_BORDER, Pin_DISCHARGE, Pin_RESET, Pin_BUSY, Pin_EPD_CS);
// I/O setup
	pinMode(Pin_RED_LED, OUTPUT);
	pinMode(Pin_SW2, INPUT);
	pinMode(Pin_TEMPERATURE, INPUT);
	pinMode(Pin_PWM, OUTPUT);
	pinMode(Pin_BUSY, INPUT);
	pinMode(Pin_RESET, OUTPUT);
	pinMode(Pin_PANEL_ON, OUTPUT);
	pinMode(Pin_DISCHARGE, OUTPUT);
	pinMode(Pin_BORDER, OUTPUT);
	pinMode(Pin_EPD_CS, OUTPUT);
	pinMode(Pin_FLASH_CS, OUTPUT);
	digitalWrite(Pin_RED_LED, LOW);
	digitalWrite(Pin_PWM, LOW);  // not actually used - set low so can use current eval board unmodified
	digitalWrite(Pin_RESET, LOW);
	digitalWrite(Pin_PANEL_ON, LOW);
	digitalWrite(Pin_DISCHARGE, LOW);
	digitalWrite(Pin_BORDER, LOW);
	digitalWrite(Pin_EPD_CS, LOW);
	digitalWrite(Pin_FLASH_CS, HIGH);
#if !defined(__MSP430_CPU__)
	// wait for USB CDC serial port to connect.  Arduino Leonardo only
	while (!Serial) {
#endif
	Serial.println("Demo G2 version: " DEMO_VERSION);
	Serial.println("Display: " MAKE_STRING(EPD_SIZE));
	FLASH.begin(Pin_FLASH_CS);
	if (FLASH.available()) {
		Serial.println("FLASH chip detected OK");
		uint8_t maufacturer;
		uint16_t device;
		FLASH.info(&maufacturer, &device);
		Serial.print("unsupported FLASH chip: MFG: 0x");
		Serial.print(maufacturer, HEX);
		Serial.print("  device: 0x");
		Serial.print(device, HEX);
	// configure temperature sensor
	S5813A.begin(Pin_TEMPERATURE);
static int state = 0;
// main loop
	int temperature = S5813A.read();
	Serial.print("Temperature = ");
	Serial.print(temperature);
	Serial.println(" Celcius");
	EPD.begin(); // power up the EPD panel
	if (!EPD) {
		Serial.print("EPD error = ");
		Serial.print(EPD.error());
		Serial.println("");
		return;
	EPD.setFactor(temperature); // adjust for current temperature
	int delay_counts = 50;
	switch(state) {
	default:
	case 0:         // clear the screen
		EPD.clear();
		state = 1;
		delay_counts = 2;  // reduce delay so first image come up quickly
	case 1:         // first image
		EPD.image(IMAGE_1_BITS);
		++state;  //next image
	case 2:         // second image
		EPD.image(IMAGE_2_BITS);
		++state = 1;  // back to first image
	EPD.end();   // power down the EPD panel
	// flash LED for 5 seconds
	for (int x = 0; x < delay_counts; ++x) {
		digitalWrite(Pin_RED_LED, LED_ON);
		delay(50);
		digitalWrite(Pin_RED_LED, LED_OFF);
		delay(50);
Hey Kevin,
I'm having the same issue, did you ever manage to figure it out?
Thanks, Jai
your problem is the COG version there are two versions for now (Vizplex V110 and Aurora Ma V230). Both are totaly diffrent to control and not compatible. (e.g.: V110 uses pwm, V230 don't)
So look at the ID-code on the backside and check which model you have. The 7. letter is important: 'A' for V110, 'B' for V230 btw. at the beginning of 2015 there should be a new COG version ...
Now my question ;) I have no experience with handling external files or images, so it could be, that my problem results in a basic lack of understanding...
If I want to add my own picture in the demo, I getting the compilingerror: 'ownpic_1_44_bits' was not declared in this scope
the code is the one Kevin77 postet above. I create the .xbm pic and added it in the folder to the given ones. But I can't find any .bits - file so i did nothing this way. I thought this would be created by the preprocessing routine.
Have i allocate some memory for the *bit - file or where is the problem?
Thanks for Help
