I am a beginner and I was hoping to find some help with my project. I have an LED sequence that I would like to loop a certain number of times - maybe 10 - when triggered by a motion sensor. My current code is posted below, I am sure there are other areas where the code could be improved or consolidated but for now I am most interested in figuring out how to repeat the twinkle function 10 times after the motion sensor is activated.
thank you very much
int calibrationTime = 30;
int value1, value2, value3, value4, value5, value6, value7, value8, value9, value10, value11, value12, value13, value14, value15;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 47; //the digital pin connected to the PIR sensor’s output
int ledPin1 = 2;
int ledPin2 = 3;
int ledPin3 = 4;
int ledPin4 = 5;
int ledPin5 = 6;
int ledPin6 = 7;
int ledPin7 = 8;
int ledPin8 = 9;
int ledPin9 = 10;
int ledPin10 = 11;
int ledPin11 = 12;
int ledPin12 = 13;
int ledPin13 = 44;
int ledPin14 = 45;
int ledPin15 = 46;
long time = 0;
int periode = 2000;
int displace1 = 200;
int displace2 = 400;
int displace3 = 600;
int displace4 = 800;
int displace5 = 1000;
int displace6 = 1200;
int displace7 = 1400;
int displace8 = 1600;
int displace9 = 1800;
int displace10 = 2000;
int displace11 = 2200;
int displace12 = 2400;
int displace13 = 2600;
int displace14 = 2800;
int displace15 = 3000;
//SETUP
pinMode(pirPin, INPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
pinMode(ledPin5, OUTPUT);
pinMode(ledPin6, OUTPUT);
pinMode(ledPin7, OUTPUT);
pinMode(ledPin8, OUTPUT);
pinMode(ledPin9, OUTPUT);
pinMode(ledPin10, OUTPUT);
pinMode(ledPin11, OUTPUT);
pinMode(ledPin12, OUTPUT);
pinMode(ledPin13, OUTPUT);
pinMode(ledPin14, OUTPUT);
pinMode(ledPin15, OUTPUT);
digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate
Serial.print(“calibrating sensor “);
for (int i = 0; i < calibrationTime; i++) {
Serial.print(”.”);
Serial.println(" done");
Serial.println(“SENSOR ACTIVE”);
delay(50);
if (digitalRead(pirPin) == HIGH) {
for (int x = 0; x < 10; x++) {
digitalWrite(13, HIGH); // set the LED on
delay(13); // wait for a second
digitalWrite(13, LOW); // set the LED off
delay(13); //
//LOOP
twinkle(10);
if (lockLow) {
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("—");
Serial.print(“motion detected at “);
Serial.print(millis() / 1000);
Serial.println(” sec”);
delay(50);
takeLowTime = true;
if (digitalRead(pirPin) == LOW) {
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
digitalWrite(ledPin5, LOW);
digitalWrite(ledPin6, LOW);
digitalWrite(ledPin7, LOW);
digitalWrite(ledPin8, LOW);
digitalWrite(ledPin9, LOW);
digitalWrite(ledPin10, LOW);
digitalWrite(ledPin11, LOW);
digitalWrite(ledPin12, LOW);
digitalWrite(ledPin13, LOW);
digitalWrite(ledPin14, LOW);
digitalWrite(ledPin15, LOW);
if (takeLowTime) {
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if (!lockLow && millis() - lowIn > pause) {
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print(“motion ended at “); //output
Serial.print((millis() - pause) / 1000);
delay(50);
void twinkle(int count)
while ( count-- )
time = millis();
value1 = 28 + 27 * cos(-2 * PI / periode * (displace1 - time));
value2 = 28 + 27 * cos(-2 * PI / periode * (displace2 - time));
value3 = 28 + 27 * cos(-2 * PI / periode * (displace3 - time));
value4 = 28 + 27 * cos(-2 * PI / periode * (displace4 - time));
value5 = 28 + 27 * cos(-2 * PI / periode * (displace5 - time));
value6 = 28 + 27 * cos(-2 * PI / periode * (displace6 - time));
value7 = 28 + 27 * cos(-2 * PI / periode * (displace7 - time));
value8 = 28 + 27 * cos(-2 * PI / periode * (displace8 - time));
value9 = 28 + 27 * cos(-2 * PI / periode * (displace9 - time));
value10 = 28 + 27 * cos(-2 * PI / periode * (displace10 - time));
value11 = 28 + 27 * cos(-2 * PI / periode * (displace11 - time));
value12 = 28 + 27 * cos(-2 * PI / periode * (displace12 - time));
value13 = 28 + 27 * cos(-2 * PI / periode * (displace13 - time));
value14 = 28 + 27 * cos(-2 * PI / periode * (displace14 - time));
value15 = 28 + 27 * cos(-2 * PI / periode * (displace15 - time));
analogWrite(ledPin1, value1); // sets the value (range from 0 to 255)
analogWrite(ledPin2, value2); // sets the value (range from 0 to 255)
analogWrite(ledPin3, value3); // sets the value (range from 0 to 255)
analogWrite(ledPin4, value4); // sets the value (range from 0 to 255)
analogWrite(ledPin5, value5); // sets the value (range from 0 to 255)
analogWrite(ledPin6, value6); // sets the value (range from 0 to 255)
analogWrite(ledPin7, value7); // sets the value (range from 0 to 255)
analogWrite(ledPin8, value8); // sets the value (range from 0 to 255)
analogWrite(ledPin9, value9); // sets the value (range from 0 to 255)
analogWrite(ledPin10, value10); // sets the value (range from 0 to 255)
analogWrite(ledPin11, value11); // sets the value (range from 0 to 255)
analogWrite(ledPin12, value12); // sets the value (range from 0 to 255)
analogWrite(ledPin13, value13); // sets the value (range from 0 to 255)
analogWrite(ledPin14, value14); // sets the value (range from 0 to 255)
analogWrite(ledPin15, value15); // sets the value (range from 0 to 255)
