Hi
I'm using some basic code to pint twitter. I'm using a duecemilia and an arduino ethernet shield.
The code below is copied from dubdubdub.mats-vanselow.de/2009/02/08/arduino-lernt-twittern/
This works absolutely fine for me - the first time. But if I try to call the sendtwitterupdate() function again, it fails to connect. I've tried this with several different sketches and get exactly the same problem: first connection is fine but any subsequent ones fail. Do I have to somehow clear the ethernet shield output before requesting a connection again or something?
Thanks in advance
Mike
#include <Ethernet.h>
Twitter Modul
2009 by Mats Vanselow
Mats-Vanselow.de
//////////// EINSTELUNGEN ///////////////////
// Etherneteinstellungen für das Arduino Board //
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 0, 99 };
byte gateway[] = { 192, 168, 0, 1 };
byte subnet[] = { 255, 255, 255, 0 };
// Twitter Settings //
byte server[] = { 128, 121, 146, 100 }; // IP von Twitter (default: 128.121.146.100)
#define TWITTERURL "/statuses/update.xml" // URL zum Update Script
#define TWITTERUSERNAMEPW "ABC=" // Base64 enkodet USERNAME:PASSWORT
Client client(server, 80);
Ethernet.begin(mac, ip, gateway, subnet); // Ethernet initalisieren
Serial.begin(9600); // Serielle Verbindung für Statusmeldungen
delay(1000); // Kurz warten, um serielle Verbindung zu starten
sendTwitterUpdate("Und jetzt kann auch das Arduino Board twittern!"); // Nachricht versenden
fetchTwitterUpdate();
/// Functions ////
void sendTwitterUpdate(char* tweet) // Nachricht an Twitter überitteln
Serial.println("connecting...");
if (client.connect()) {
Serial.println("connected");
client.print("POST ");
client.print(TWITTERURL);
client.println(" HTTP/1.1");
client.println("Host: twitter.com");
client.print("Authorization: Basic ");
client.println(TWITTERUSERNAMEPW);
client.print("Content-Length: ");
client.println(9+strlen(tweet));
client.println("");
client.println("status=");
client.println(tweet);
Serial.println("twitter message send");
Serial.println("connection failed");
void fetchTwitterUpdate() // Rückmeldung von Twitter auslesen
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
