Hi! Can anyone help me with this code. It's a Countdown timer with TM1637 display and rotary encoder. When timer counts down to 00:00 need to start counting again from the beginning...over and over.
Thanks.
P.S. sorry for bad english
#include <ClickEncoder.h>
#include <TimerOne.h>
#include <Time.h>
#include <TimeAlarms.h>
#include <TM1637Display.h>
#define CLK 2
#define DIO 3
const int BTN_START_PIN = 6;
const int PIEZO_PIN = 12;
const int ENC_PIN_1 = 4;
const int ENC_PIN_2 = 5;
const int ENC_PIN_3 = 8;
ClickEncoder *encoder;
int16_t last, value;
TM1637Display display(CLK, DIO);
uint8_t data[] = { 0xff, 0xff, 0xff, 0xff };
bool started = false;
bool clockTimeSet = false;
bool finished;
int buttonStartState = 0;
int timerHours = 0;
int timerMinutes = 0;
int timerSeconds = 0;
void timerIsr() {
encoder->service();
encoder = new ClickEncoder(ENC_PIN_1, ENC_PIN_2, ENC_PIN_3);
Timer1.initialize(1000);
Timer1.attachInterrupt(timerIsr);
last = -1;
pinMode(BTN_START_PIN, INPUT_PULLUP);
pinMode(PIEZO_PIN, OUTPUT);
if (!started) {
value += encoder->getValue();
if (value > last) {
timerMinutes++;
calculateHours(true);
} else if (value < last && timerMinutes > 0) {
timerMinutes--;
calculateHours(false);
if (value != last) {
last = value;
Serial.print("Encoder value: ");
Serial.println(value);
ClickEncoder::Button b = encoder->getButton();
if (b != ClickEncoder::Open) {
Serial.print("Button: ");
#define VERBOSECASE(label) case label: Serial.println(#label);
switch (b) {
VERBOSECASE(ClickEncoder::Pressed);
VERBOSECASE(ClickEncoder::Held)
VERBOSECASE(ClickEncoder::Released)
VERBOSECASE(ClickEncoder::Clicked)
case ClickEncoder::DoubleClicked:
Serial.println("ClickEncoder::DoubleClicked");
encoder->setAccelerationEnabled(!encoder->getAccelerationEnabled());
Serial.print(" Acceleration is ");
Serial.println((encoder->getAccelerationEnabled()) ? "enabled" : "disabled");
buttonStartState = digitalRead(BTN_START_PIN);
if (buttonStartState == LOW) {
Serial.println("Start button pressed");
started = true;
finished = isTimerFinished();
if (!finished) {
Alarm.delay(1000);
decreaseTime();
Serial.println("Timer finished");
tone(PIEZO_PIN, 1000, 500);
display.setBrightness(0x0f);
display.showNumberDecEx(timeToInteger(), (0x80 >> 1), (timerMinutes / 10) == 0);
int timeToInteger() {
int result = 0;
result += timerMinutes * 100;
result += timerSeconds;
return result;
void decreaseTime() {
Serial.print(timerHours);
Serial.print(" Hours ");
Serial.print(timerMinutes);
Serial.print(" Minutes ");
Serial.print(timerSeconds);
Serial.println(" Seconds");
if (!finished)
timerSeconds--;
void calculateHours(bool asce) {
if (timerSeconds == -1 && !asce) {
// decrement minutes
if (timerMinutes > 0 || timerHours > 0) {
timerMinutes--;
timerSeconds = 59;
if (timerMinutes == 60 && asce) {
timerHours++;
timerMinutes = 0;
} else if (timerMinutes == -1 && !asce && timerHours > 0) {
timerHours--;
timerMinutes = 59;
bool isTimerFinished() {
return timerHours == 0 && timerMinutes == 0 && timerSeconds == 0;
