I have 2 steppers and drivers that are the same. This set up and code work great for the one motor which uses a pot. But then for the second motor I need to use 2 buttons instead of the pot (momentary switches, one forward and one reverse). Is there a way to change the code so that I can use the buttons instead of the pot?
#include <AccelStepper.h> // accelstepper library
AccelStepper stepper(1, 8, 9); // direction Digital 9 (CCW), pulses Digital 8 (CLK)
//Pins
const byte Analog_X_pin = A1; // x-axis readings
const byte enablePin = 7;
//Variables
int Analog_X = 0; //x-axis value
int Analog_X_AVG = 0; //x-axis value average
//PINS
pinMode(Analog_X_pin, INPUT);
pinMode(enablePin, OUTPUT);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
InitialValues(); // averaging the values of analog pin 0 (value from potmeter)
// Stepper parameters
// setting up some default values for maximum speed and maximum acceleration
stepper.setMaxSpeed(2000); //SPEED = Steps / second
stepper.setAcceleration(1000); //ACCELERATION = Steps /(second)^2
stepper.setSpeed(1000);
ReadAnalog();
ReadLimits();
stepper.runSpeed(); //step the motor (this will step the motor by 1 step at each loop indefinitely)
void ReadLimits()
if( digitalRead(2)==LOW && stepper.speed()>0 )//read input, assuming they have pull-up resistors.
stepper.setSpeed(0);
if( digitalRead(3)==LOW && stepper.speed()<0 )//read input, assuming they have pull-up resistors.
void ReadAnalog() {
if (abs(Analog_X-Analog_X_AVG) > 50) {
digitalWrite(enablePin, HIGH); // enable the driver
stepper.setSpeed(5*(Analog_X-Analog_X_AVG));
digitalWrite(enablePin, LOW); // disable the driver
// Reading the potentiometer in the joystick:
Analog_X = analogRead(Analog_X_pin);
// if the value is 25 "value away" from the average (midpoint), we allow the update of the speed
// This is a sort of a filter for the inaccuracy of the reading
stepper.setSpeed(5 * (Analog_X-Analog_X_AVG));
void InitialValues() {
//Set the values to zero before averaging
float tempX = 0;
// read the analog 50x, then calculate an average.
// they will be the reference values
for (int i = 0; i<50; i++) {
tempX += analogRead(Analog_X_pin);
delay(10); //allowing a little time between two readings
Analog_X_AVG = tempX/50;
Serial.print("AVG_X: ");
Serial.println(Analog_X_AVG);
Serial.println("Calibration finished");
