Replace delayMicroseconds() with micros()
Hello everyone!
I’m trying to make an AC control for lamps. There is a zero crossing detector that sends a pulse to Arduino everytime the sine wave passes thru 0. This pulse activate an ISR that generates another phased pulse to trigger the TRIAC. In near future, I will add other lamps that will be controlled separately with potentiometers. The delayMicroseconds() won’t let me control multiple lamps, so I want to replace it with micros() (code below). I need to get rid off delays cuz the readings can’t be late. I need simultaneously readings from multiple potentiometers.
  • The code is working perfectly with one lamp/pot. I haven’t tested with more lamps yet.
  • Graphs: [Attached images]
    blue line: zero-cross signal
    red line: dimmerized signal (phased signal)
    green line: load sine wave
Thx
#define dimmer 5
volatile long pot = 0.0; // potentiometer read
void zeroCross() {
    // Calculates t1
  long t1 = 8333L * (100L - pot) / 100L;
  delayMicroseconds(t1);
  digitalWrite(dimmer,HIGH);
  delayMicroseconds(10);
  digitalWrite(dimmer,LOW);
  pinMode(dimmer, OUTPUT);
  digitalWrite(dimmer, LOW);
  attachInterrupt(0, zeroCross, FALLING);
  pot = map(analogRead(A0), 0, 1023, 1, 90);
  delay(10);
}[\code]
Just use this https://forum.arduino.cc/index.php?topic=223286.0 and replace millis() with micros().
Just keep in mind that the Arduino micros() resolution is 4 microseconds and overflows every 70 minutes.
The ESP32's equivalent of micros resolution is 1 microsecond and overflows in a bit more then 100 years. Then again you'd not need micros() with a ESP32. The OS, freeRTOS, built into the ESP32 is multitasking and multithreading.
Disparaging posts REMOVED.
@danicomartins
Could you use code tags please ( </> )
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
